Replacement rear fender bolts
and thats
Mid Fifty F-100 Parts - Home
there is also
LMC - Truck Parts and Truck Accessories for Chevy, GMC, Ford and Dodge Trucks from LMCTruck.com
Dennis Carpenter - Dennis Carpenter Ford Car, F-100 Pickup Truck, 8N, 9N Tractor and Cushman Scooter Restoration Parts
MAR-K - MAR-K Classic Truck Parts made in Oklahoma City, USA
and a dozen others..
Sam
there is also
Sam
Fender bolts
Dang!! Are the rear fender bolts spot welded in or something. The front fender bolts popped right out but the back ones are TIGHT man. I broke some removing the fenders and now I decided I would change all of them out to new bolts so they all match but I they don't budge when I try to punch them out. Any ideas anyone. Thanks
Remi
Remi
Yep! They're welded into the sides of the bed. They can be a booger to remove. Just take your time.
And, you're right, Midfifty deals primarily with the 53-56 stuff. You need to call they're sister (literally--the owners are sisters) company. Classic Haulers in Indiana. Classic Haulers F-1 Parts - Home
Any suggestions? Drill, air chisel, torch, plasma cutter...... new box sides that don't have them. I would leave them in there and re-use them but the ends on quite a few of them stripped when I was taking the nuts off so I want to replace the whole works with new flathead bolts. The kind with the large flat head that use the allan key wrench.
ericconn
10-03-2013 11:10 PM
Adriand
15
09-07-2008 06:23 PM
rchassie
02-07-2005 09:41 AM
