Driver side door problem
My '95 F150 driver-side door doesn't seem to line up quite right with the door frame. It's a minor problem, really. There is a slight amount of vertical play in the door. When I get out and close the door, I lift the door a bit by the handle so it closes cleanly. If I don't lift, it closes, but I have to close it a bit harder to get it to latch. Like I said, it's not a big problem, but I don't want it to get any worse. Maybe there is away to shim the door just a bit to bring the latch back in line with the frame?
I have had the same problem. All you need to do is replace the bushings and pins in the hinges on the door. You can get a pin and bushing kit at your local auto parts store. It should take about a good 30 to 45 minutes to change them and you should not have any more problems with your door, it will close just like it was new, well at least mine did anyway ha ha ha. What ever you do, do not adjust the striker until you replace the pins and bushings first. In most cases the striker doesn't need to be adjusted at all.
