Project TGM - Page 58 - Ford Truck Enthusiasts Forums
Project TGM
  #856
Old 12-12-2012, 05:01 PM
1_ton_bronco's Avatar
1_ton_bronco 1_ton_bronco is offline
1_ton_bronco is gaining momentum as a positive member of FTE.
new signature?
  #857
Old 12-12-2012, 05:04 PM
FordFETruck's Avatar
FordFETruck FordFETruck is offline
FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.
Quote:
Originally Posted by 1_ton_bronco View Post
new signature?
HAHAHAHAHAHA I'll think about it. Probably make a lot of people laugh.
  #858
Old 12-12-2012, 05:07 PM
noo look at mine lol
  #859
Old 12-12-2012, 05:08 PM
HAHAHA, that made my day
  #860
Old 12-12-2012, 05:12 PM
LMFAO it was worth getting rid of the old trucks for that
  #861
Old 12-12-2012, 05:14 PM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
Ahh!! No thank you
  #862
Old 12-12-2012, 05:27 PM
lmao artic
  #863
Old 12-12-2012, 05:28 PM
When I posted that originally it was a legitimate question, now it's a sick and twisted one LOL
  #864
Old 12-12-2012, 05:44 PM
gonna stay in my signature now.. Lol
  #865
Old 12-12-2012, 07:39 PM
GruesomeJeans's Avatar
GruesomeJeans GruesomeJeans is offline
GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.
Haha jeeze you guys, I thought I was bad. Matt I can get a picture but this linkage can't be bent to lengthen it. I already looked into that, there is a linkage that goes from the choke bar over the carb and to the choke piece. that was a little bent so I straightened it but it didn't get it to close enough. Since the linkage from the thermo spring is from my 2bbl it isnt really the correct one. I will get it all figured out though.
I had thought about converting to a manual choke, I know I could buy the cable but I don't know if that would be cheaper than using an electric one. I also will have to find a hole in the firewall cause I don't have a drill bit that can go that big I don't think. Would I just buy the cable and bolt it to the choke lever then run it through the firewall and find a place on the dash to mount it?
  #866
Old 12-12-2012, 08:24 PM
Quote:
Sounds like a personal problem? LOL just kidding.
If it's the linkage that goes from the choke assembly to the bar that is connected to the choke then Carter 4 AFB Parts Page go down until you see the AFB choke and fast idle linkage set, seems pretty cheap. I'd look around online some more, I already tried looking around some but am having a hard time doing so. Before I discovered my actual choke linkage and carb installation parts under my seat I made a linkage out of a coat hanger, it was very crude but worked good LOL
  #867
Old 12-12-2012, 08:29 PM
You know, i thought about that before hand. Thats why i said linkage instead of rod
Thanks for the link i wil skim it over and see if i can find anything, i never thought about using a coat hanger. I was going to use a big paperclip and form it to what i need. I have a lot of extra metal hangers which could do the trick just fine.
Wow so i just looked over that pars list page you posted matt and it has everything i have been looking for. Shoot. Unfortunately i can't afford What i need just yet, maybe i could get my mom to buy them as an xmas present or something.
  #868
Old 12-12-2012, 08:31 PM
Hahaha, I looked at the shipping on that site, pretty expensive. I wonder if Oreilly's sells the choke linkage under the Edelbrock name in the Auburn store, seems like I've seen it there before. The coat hanger linkage I made in 5 minutes, I could have made a better one but it worked for a few days before I looked under my seat and found the bag of parts with some bodies
  #869
Old 12-12-2012, 08:50 PM
Haha, I wrote down the part numbers for each and i figured i would try oreilly's and Napa to see if they had might have them. The oreilly's is pretty good about knowing their carb parts but i won't know till i go up there and ask. It's easier to drive up there and make sure rather than call them so there isn't any mistakes.
EDIT: also i could end up using the coathanger but i would probably take a little more time to make some sort of fastener thing. I don't think i could make the groove for a C clip like the current one.
  #870
Old 12-12-2012, 08:51 PM
Yeah, man when I bought carburetor studs at Autozone I asked the guy if they had them and he looked at me like a deer in the headlights and didn't know what they really were. He eventually found them though. Great service eh?
Lessons learned fixing my front end and wandering problems AMG-SM Brakes, Steering, Suspension, Tires, & Wheels 58 05-04-2016 05:14 PM
Super duty steering box 2002f350sd 1999 - 2003 7.3L Power Stroke Diesel 6 03-18-2011 05:04 PM
alignment after new tie rod and ends? bradoemba 1948 - 1956 F1, F100 & Larger F-Series Trucks 37 12-20-2010 09:22 AM
DJM Drop Beams on '66 F-100 2Wd - my experience echobunny 1961 - 1966 F-100 & Larger F-Series Trucks 19 07-12-2010 12:16 PM
Wheel Vibrations nickh829 General Automotive Discussion 1 04-02-2005 11:52 AM
Tags
1978, 1997, 2003, battery, broke, cable, end, explorer, flywheel, ford, location, negative, projects, ranger, starter, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
