Tight spot in steering
01-06-2012, 04:33 PM
on
I have a 1978 F250 4x4 supercab and it is in excellent mechanical condition aside from a strange tight spot in the steering. about every 1/2 turn of the wheel It gets tight for a split second and then smooth again. it does it both ways and probably twice to a full revolution... other than that it steers well, any pointers where I should check for the solution. the front end istight and lubed. I am REALLY hoping that its not the gear box and if so I hope I can cure the problem without a new box.
01-06-2012, 04:41 PM
Check the universal in the steering coupler. Mine did that and I found the universal was rusted and binding. A little penetrating oil freed it up then grease and haven't had a problem since.
01-06-2012, 05:04 PM
Yup, what he said. ^^^
I'd bet money it's in the column.
01-06-2012, 06:57 PM
on
Damn, that seems obvious... I will check it out and report. Thanks
01-06-2012, 09:43 PM
It could also be a froze up front axle U joint. Turn the wheels all the way in either direction then reach in and turn each axle by hand at the U joint.
kh64
18
09-05-2012 07:01 PM
midsouth
04-06-2012 07:01 PM
ruggles
06-20-2009 02:04 PM
WYO92350
11-15-2006 08:14 PM
Bronco-Red
1978 - 1996 Big Bronco
06-07-2004 01:05 PM
4x4,
97,
american,
diesel,
f100,
f150,
ford,
hard,
spots,
sreering,
steering,
style,
tight,
truck,
wheels
