Slow crank - Ford Truck Enthusiasts Forums
Slow crank
Old 01-06-2012, 01:13 PM
rangergirl94's Avatar
rangergirl94 rangergirl94 is offline
rangergirl94 is starting off with a positive reputation.
Slow crank
I have a 93 f150 4.9 I replaced starter,batt,cleaned connections it cranks slow sometimes gotta jump it to start it also replaced battery terminals any help please?
Old 01-06-2012, 02:21 PM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
You need to check the voltage at the battery posts while the engine is running. Should be around 13.6 - 14 VDC.
Sounds like a low battery charge.
Old 01-06-2012, 02:58 PM
I took the battery out and put in another truck it cranks fine just wont crank mine?
Old 01-09-2012, 03:33 PM
Its cranks fast and starts fine if its cold if its warm it cranks very slow??
Old 01-09-2012, 04:13 PM
mpc07005's Avatar
mpc07005 mpc07005 is offline
mpc07005 is starting off with a positive reputation.
What was the other truck? Still check with a multimeter. By cold do you mean a cold day or motor (I'm assuming cold motor, but thought I'd check)? Is it taking a long time to start or turning over slowly (turning slow implies a longer start duration)? Try swapping another battery in, and see if it still cranks slow. Engines should be easier to turn when warm, not cold. What's the oil like? I'll try to think of what would cause that (only thing that comes to mind is a very overzealous injector, but there are no other apparent symptoms).
-Mike
Old 01-09-2012, 05:57 PM
Ive changed the battery and yes cold motor changeed starter and batt terminals cleaned all connections ? Short somewhere maybe but wouldnt it do it cold or warm?
Old 01-09-2012, 07:21 PM
88n94 88n94 is online now
88n94 is gaining momentum as a positive member of FTE.
I would take a remote starter switch and hook it direct to the starter. ie one terminal of the remote starter switch on the large battery cable terminal and one terminal on the small electrical bolt. You could do the same thing by taking a screwdriver and connecting those two terminals, but this would be safer. That would bypass a lot of stuff. Just for troubleshooting of course. Do you have a manual or an automatic transmission?
Old 01-09-2012, 08:11 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Which "connections" did you clean? A poor ground connection at the block can manifest itself as you have described. Sometimes a battery cable will develop corrosion under the insulation. Something else to look for.
Old 01-09-2012, 08:20 PM
73'360f100's Avatar
73'360f100 73'360f100 is offline
73'360f100 is starting off with a positive reputation.
I would redo all of your grounds with some good quality welding cable. Bad grounds can cause slow starting and I can almost guarantee that you could use new grounds.
Old 01-09-2012, 09:24 PM
Ill try new grounds I put a new one from neg batt post to fender and also crossed the screwdriver trick still nothing
Old 01-10-2012, 07:43 AM
rla2005's Avatar
You need to focus on the ground from the battery to the engine block.
Old 01-10-2012, 02:39 PM
The neg cable runs to the starter?
Old 01-10-2012, 03:01 PM
rla2005's Avatar
The negative cable runs to the engine block, not the starter. Your truck may or may not have the extra tab that also connects to the frame.
Take a look at Post #9 in this thread: http://www.ford-trucks.com/forums/10...ml#post9965674
Bill has some great photos of where the grounds are.
Old 01-10-2012, 03:36 PM
None of my trucks have an engine ground all go to the bottom starter bolt its i6 not v8
Old 01-10-2012, 04:41 PM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
Quote:
You did what? The negative cable runs from the battery to the starter bolt. The positive cable runs from the battery to the relay to the starter.
Also, when you say you put a new ground on, what exactly did you replace? Just the end of the cable? I have had terrible luck with just the ends. Replace the whole cable with a one-piece molded cable. They work much better.
I really think that your battery cables are shot. It's a common problem on older vehicles. The cable insulation dries out, cracks and deteriorates. This lets water in which corrodes the cables are reduces their current-carrying capacity.
You've replaced everything else. Spend $20 and put new cables on it - the thickest ones you can find - and I bet your problem goes away.
One other thing - what's your base timing set to?
4.9 slow crank lost help asap Hatchdemon89 1987 - 1996 F150 & Larger F-Series Trucks 8 11-02-2016 10:26 PM
78 351M having issues starting max burroughs 1978 - 1996 Big Bronco 6 11-02-2014 04:33 PM
HELP 7.3 IDI slow no start firegod75 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 07-04-2014 01:14 PM
slow crank mknapik Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 01-17-2014 01:21 PM
Dead battery... MattyNJ 6.0L Power Stroke Diesel 39 01-15-2009 01:21 PM
Tags
1986, 1992, 1994, 2000, 58l, 73, 94, battery, crank, cranking, cranks, expedition, f150, f250, ford, good, slow
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
