Is it a 360 or 390? - Ford Truck Enthusiasts Forums
Is it a 360 or 390?
Old 01-06-2012, 08:56 AM
PIDI PIDI is offline
PIDI is starting off with a positive reputation.
Is it a 360 or 390?
OK dumb dumb here has two questions?
One how do you know if its a 360 or 390 (heard it depends on the cam??)
Two how do you do an advanced search tried 360 vs 390 gave me all the numbers, then what engine and it did it by engine. So how in the world do you limit the search to find the words combined??
Any help would be great thanks!!
Old 01-06-2012, 09:08 AM
DeepRoots DeepRoots is offline
DeepRoots is gaining momentum as a positive member of FTE.DeepRoots is gaining momentum as a positive member of FTE.
Old 01-06-2012, 09:40 AM
Sleepy445FE's Avatar
Sleepy445FE Sleepy445FE is online now
Sleepy445FE is gaining momentum as a positive member of FTE.Sleepy445FE is gaining momentum as a positive member of FTE.
That FAQ is a great resource. Displacement is measurement of bore size and stroke. The cam has nothing to do with it.
360= 4.05" bore x 3.5" stroke
390= 4.05" bore x 3.784"
An easy way to check the stroke is to pull the #1 and #4 spark plugs. Insert a dowel into #1 plug hole and bring it up to TDC. Mark the dowel. Now put the dowel in #4 and make a mark in the same fashion. The distance between the two marks is the stroke.
3.5"=352/360
3.784"=390/406/427 (very doubtful it's anything other than a 390)
3.984"=410/428
To make a final determination you'd have to pull a head and measure the bore.
Old 01-06-2012, 10:12 AM
ford_pickup ford_pickup is offline
ford_pickup is starting off with a positive reputation.
Ingenious
3.5"=352/360
3.984"=410/428
Wow, thanks for that idea, so much easier than cranking from TDC to BDC, you learn something new every day
Old 01-06-2012, 08:52 PM
Great info I do appreciate it.... No duh on the stoke huh whats that got to do with a cam should have thought before speaking
360 to 390 rebuild 74f100sc 1973 - 1979 F-100 & Larger F-Series Trucks 15 02-23-2016 11:26 PM
390/360 Crank Bolt/Nut question AK FORD GUY FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 4 08-12-2009 08:41 PM
360vs390firing order boxer.fan FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 43 04-02-2009 04:33 PM
rod length? Jeff's Secretary FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 35 08-28-2007 08:28 PM
Engine balancing for a 460 w/ 360/390 flywheel txen Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 9 05-08-2007 01:39 AM
Tags
360, 390, 76, bore, diesel, f100, f250, father, ford, restore, son, spark, stroke, truck, vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
