Help, flashing "security" light - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-06-2012, 03:31 AM
newfordy newfordy is offline
newfordy is starting off with a positive reputation.
Question Help, flashing "security" light
On an '08 E-450 stripped chassis(not an truck, i know) with gas engine.
The "security" light(car with lock icon) flashes rapidly when the ignition is turned on and the digital odometer goes to flatline. After one minute the icon gives a flash code(?) of 1 - 6.
This vehicle is not PATS equipped.
Vehicle will not start or even crank. Batteries are up, starter will turn engine over when operated with remote push button starter.
Any ideas? I can borrow a Rotunda scanner.
Old 01-06-2012, 04:00 AM
carltonwebb's Avatar
carltonwebb carltonwebb is offline
carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.
What letters are on the shank of the key?
Old 01-06-2012, 04:30 AM
Try resetting the KAM by removing the battery ground cable for 5 minutes. Maybe check fuses 14 and 15 in central junction box. Thats all I can think of without a scanner. I cannot find a flash code chart for the PATs system
Old 01-09-2012, 06:42 PM
Smile Update...Got it fixed. Details inside-FWIW
In the hope of maybe helping someone else out there.
In addition to above symptoms, found fuse #23(PCM and other) in underhood fusebox blown, also Rotunda scanner would not connect to PCM but would connect to Instrument Cluster module.
Replaced fuse and immediately blew on "ignition-on".
Found, drivers side Heated Oxygen Sensor connector power wire had rubbed through shorting directly to ground at rear of LH cylinder head.
To test, I removed fuse #23 and vehicle exhibits exact symptoms, replace and all is normal.
Hope this info may help someone.
"PATS NO START": lhreddin 1999 to 2016 Super Duty 2 10-23-2016 07:07 PM
Security Light Flashed Today On Idle mjmck 1999 to 2016 Super Duty 2 03-11-2016 07:22 AM
starter not engaging/check guages displayed tompkinsmi 2004 - 2008 F150 4 08-17-2014 02:20 AM
Urgent help needed!!! joshbea6 Explorer, Sport Trac, Mountaineer & Aviator 9 08-11-2014 12:57 PM
security light flashing luthrobediesel 1994.5 - 1997 7.3L Power Stroke Diesel 1 12-31-2009 08:01 PM
Tags
2008, diesel, edge, f150, flashes, flashing, ford, icon, light, lock, padlock, pats, quickly, ranger, security, starting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
