Texas Chapter Join Chapter, Leader: LibTimothy
Anyone in SanAntonio with AE?
Old 01-05-2012, 08:42 PM
LSAtexan4x4's Avatar
LSAtexan4x4
LSAtexan4x4 is offline
I want to run a contribution test... Having a hard time fixing my stumble in my 6.0l
I'll compensate
Thanks
Old 01-05-2012, 10:47 PM
DRRXR's Avatar
DRRXR
DRRXR is offline
I'll compensate
Thanks
Good luck with that heres a bump.
Whats it doing exactly?
Old 01-06-2012, 02:54 AM
orionife's Avatar
orionife
orionife is offline
What is a "contribution test" and a "bump"
Old 01-06-2012, 05:42 AM
DRRXR's Avatar
DRRXR
DRRXR is offline
Short answer
A cct is a test to see what what each cly is contributing to the load placed on the vehicle. Its a way to test injector performance and id issues. On Di diesels the pcm/ecu works the idm/ficm to compensate for weak cylinders. I can gprs into that further but not from this iphone. Oh and good morning.
Old 01-06-2012, 05:46 AM
DRRXR's Avatar
DRRXR
DRRXR is offline
Dang iphone. Not gprs above. I meant "go"
Old 01-06-2012, 09:56 AM
TXtinct's Avatar
TXtinct
TXtinct is offline
You'll shoot your eye out
If you are going to the Houston area Tech day, I know TD has one and I'm sure a few other do as well. I don't know of any local though.
Old 01-06-2012, 12:44 PM
LSAtexan4x4
Ya I know td does he's helped me... But I wanted to get what I needed for the tech day ah well
Old 01-06-2012, 02:34 PM
orionife's Avatar
orionife
orionife is offline
Thanks for the info, and good morning...well afternoon now.
I wish I could but a Navy buddy in Dallas in retiring on the 20th so will not be able to make it, hopefully the next one.
Old 01-07-2012, 11:28 PM
LSAtexan4x4
TD helped me out with his while he was in town today... no such luck ...
i gues off to ford i go for some cold start diagnostics
Old 01-13-2012, 04:21 PM
craftkr's Avatar
craftkr
craftkr is offline
I got a buddy in Bastrop, and he's working at Empire Diesel in Cedar Park now. He has AE and pretty good with it. Let me know if you need his contact info. And both he and I drive 6.0's as well.
And FYI go to a synthetic oil for your 6.0. I ran Rotella T-6 and now running Amsoil. Helps stiction issues on those damn injectors, and cold starts. The HPOP's on these damn 6.0's shear the oil down to a 30 wt. So don't run reg.dino oils. Atleast a synthetic blend.
I see you already had your FICM worked on too... I'm on my 2nd 6.0, first I traded in with 289k miles (2003), my 2005 just rolled 207k miles. Good powerplant if you take care of the little stuff with'em.
Old 01-13-2012, 05:19 PM
LSAtexan4x4
Would your buddy by chance be in sanantonio ever?
Old 01-14-2012, 09:58 PM
craftkr's Avatar
craftkr
craftkr is offline
I'll check with him.
Old 02-08-2012, 04:08 PM
TXtinct's Avatar
TXtinct
TXtinct is offline
Okay, now I need help in the San Antonio area. AE anyone?
Old 02-09-2012, 12:32 AM
Snuggyworm's Avatar
Snuggyworm
Snuggyworm is offline
wats wrong? i tink rossie's the one wif the AE. as far as i know. u know me, i could be wrong on tat assumption. hehehe.
Old 02-09-2012, 08:42 AM
TXtinct's Avatar
TXtinct
TXtinct is offline
Yes but he is not in San Antonio. I think I will be purchasing one pretty soon.
Quick Reply: Anyone in SanAntonio with AE?
