Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks > 1961 - 1963 F100 Unibody
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
  #1 (permalink)
Old 01-05-2012, 05:37 PM
major562 major562 is online now
Garage is empty, add now
major562 is starting off with a positive reputation.
data plate decode
I have a 1962 unibody vin/ f10JH206883 with data plate in glove box wb 114 color L model f-100 trans A Axel 11 114 hp @ 3600 rpm. I think it is pretty much original except it is now green and white. It looks like a 223 straight 6 with 3 on the tree. Is trans code A a light duty 3 speed manual and what is axel code 11. Also does color L mean Holly green only. also the cover around the speedometer and gauges is white. Would it originally have been green or chrome. I only found this forum a few days ago and love it. Thanks for any info. John
  #2 (permalink)
Old 01-05-2012, 10:00 PM
Bill W's Avatar
Bill W Bill W is offline
1963 Ford F-250
My Garage
Bill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputation
Hi John, Welcome to FTE!
okay, lets start with F10"JH" J=223 I6 and H= built in Lorain Ohio. "206883" built in Febuary 1962, Color L= Dark Green Trans A=3 speed standard. Axle code 11= 3.70 to 1 gears, 9 inch rear. white would be the correct color for the dash speedo if it's not a custom cab truck, custom cab's have a chrome piece.
Good Luck with your new project.
  #3 (permalink)
Old 01-06-2012, 06:44 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by major562 View Post
I have a 1962 unibody. VIN: F10JH206883 with Warranty Plate in glove box: W.B. 114 / Color L / Model F100.
Also does color L mean Holly Green only.
Welcome to FTE
VIN series code, first 3 digits: F10 = F100 2WD
114" Wheelbase.
Model F100 = F100 2WD, 5,000 lbs. Gross Vehicle Weight Rating.
L = Holly Green (Ford promotional name) / L = Dark Green (actual color).
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #4 (permalink)
Old 01-06-2012, 08:49 AM
Thanks for the help. Just trying to learn as much as possible about the truck. I just started working on it. I am about to order a shop repair manual. Besides this forum are there any books, magazines or articles you would reccommend before I begin any serious repairs to the truck. I just tuned it and got the lights working. Compression on the cylinders is between 82 and 100. I plan on keeping the truck close to original and start on the brakes so I can drive it a little and then try to deal with the body work and rust. Thanks again. John
  #5 (permalink)
Old 01-08-2012, 10:37 AM
kjvforme's Avatar
kjvforme kjvforme is offline
1962 Ford F-100
kjvforme has a very good reputation on FTE.kjvforme has a very good reputation on FTE.kjvforme has a very good reputation on FTE.kjvforme has a very good reputation on FTE.
F10JH206883 should be August of 1961 assembly date, my database has you having the oldest 1962 Unibody so far that I have recorded. The first built being 205001, that makes your truck 1,882 built for 1962. congratulations
Rob
__________________
Rob
1962 Ford F100 flat bed 4x4, 223, 4spd.
1962 Ford F100 Unibody with Olds 330 & Jetaway
1944 Ford GPW (Jeep) with 1947-48 Willys L-134
To join the Oregon Chapter, click HERE
  #6 (permalink)
Old 01-08-2012, 02:37 PM
thanks for the info.
  #7 (permalink)
Old 04-04-2012, 06:54 PM
NewtonsApples NewtonsApples is offline
NewtonsApples is starting off with a positive reputation.
Data Plate Decoder
  #8 (permalink)
Old 04-04-2012, 11:21 PM
kjvforme's Avatar
1962 Ford F-100
At the top of the page under article/specs. If you want more post the info off of the warranty plate and let us take a look at it.
__________________
Rob
Tags
100, 1962, 2002, codes, data, engine, expedition, f150, ford, plate, plates, series, transmission, truck, unibody, warranty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
