1997 F250 Converting Rear Drums to Disc's - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 01-05-2012, 06:09 PM
rstazick rstazick is offline
rstazick is starting off with a positive reputation.
Has anyone converted their rear drums to disc's? I am trying to weigh out my options. I am now going to be towing a 3 horse gooseneck, 21' on the floor and approximately 10,000 lbs. I have done some of the power mods, Super Chip, Bully Dog Down Pipe, cat removed,Tymar intake to be installed soon.
My 97 has only 91,000 miles on it but I am hoping the 355 gearing will be OK.
I am willing to put some $ in the 97 before I look for another rig.
Thanks,
Old 01-05-2012, 07:00 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Lots of guys have, if you google 96F250rear disc brakes you will find a bunch of info. My 3.55's work fine with my trailer (16k loaded). I do have upgraded injectors, but I think you will be ok. I used to pull a 30 footer enclosed, truck was stock then and worked ok, but in a decent wind it struggled. About the same weight as yours, maybe a little more but it was an extra height box of a trailer (bumper pull).
Auto or manual transmission?
Old 01-05-2012, 07:04 PM
joe_13894 joe_13894 is offline
joe_13894 is gaining momentum as a positive member of FTE.joe_13894 is gaining momentum as a positive member of FTE.
There are several write ups on this forum. One is here:
http://www.ford-trucks.com/forums/10...onversion.html
IMNSHO I'd go for disk brakes on the trailer over doing the brake conversion on the truck. Rather than making the truck stop the trailer, make the trailer stop itself. Electric drum trailer brakes are worthless. Most don't have slack adjusters on them. You can get conversion kits for most axles, and a electro-hydraulic unit to apply them.
I'd also check out the condition of the slack adjusters on the truck brakes. They do wear out and that's why the drum brakes don't work well. For $15 per side you can replace all of the slack adjuster parts.
Old 01-05-2012, 07:10 PM
PowerstrokeRyan's Avatar
PowerstrokeRyan PowerstrokeRyan is offline
PowerstrokeRyan is starting off with a positive reputation.
My rear disc brake conversion - PowerStrokeArmy helped us out when we did it to my uncles truck recently.
Old 01-05-2012, 11:57 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
I used these years ago and they are still going stronge, TSM MFG. CO., INC..
I agree with you Joe, disk brakes on the trailer. I used to sit on the end of my seat with sweat rolling down my back. Last summer I put disk brakes on my 5th wheel in my signature and just joking around I say "now I feel like I can tailgate someone". They are better then great!!
Old 01-09-2012, 06:13 AM
stainlessstroker95's Avatar
stainlessstroker95 stainlessstroker95 is offline
stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.
Quote:
Glenn, how hard was the conversion with the kit you used? Was it a direct bolt on? Did you get the e brake too. How much did you spend on it if you dont mind me asking?
Old 01-09-2012, 10:23 AM
Quote:
The kit is a direct bolt on except for the brake lines. I had to bend them some to get them to connect to the new calipers. I got the e brake ones and they also work good. I did it probably six years ago and can't remember of much. It was something around six hundred guessing. I bet they are a lot more now. Customer service is very good. A couple of years ago I was wearing a grove in the rotor hub and he told me what to do about it.
Old 01-09-2012, 05:41 PM
Thanks for the info glenn. I think i need to start getting the drive train up to snuff befor i worry bout the performance parts for the engine. This seems like a really good upgrade. I need to work on my brakes any way and get a good e brake since i have a 5 speed.
2002 f150 rear axle drum to disc brakes 97anny 1997 - 2003 F150 1 01-25-2016 06:59 AM
Drum to Disc brake conversion using Explorer disc brakes FLJ Brakes, Steering, Suspension, Tires, & Wheels 4 09-08-2015 01:42 AM
'97 F150 Rear Drum to Disc Conversion lbftbljck 1997 - 2003 F150 18 08-16-2011 12:13 AM
1975 F250 Dana 60 Drum to Disc? HOW! castone001 1973 - 1979 F-100 & Larger F-Series Trucks 9 04-18-2009 02:13 AM
Disc brake conversion on rear... dave boley Aerostar 24 02-16-2009 05:42 PM
Tags
1997, 2wd, 73l, 97, brakes, convert, diesel, disc, drum, drums, f250, hd, pulling, rear, recommended
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
