ok so i have a 1985 f150 straight 6 ,4.9L
the head gasket needs to be changed and i have never done this be for so and advice or tips on how to do it would be great
You really need to buy a manual. The best is the factory shop manual, but a Chilton's or Haynes will suffice. There are way too many details for us to relate to you, and if you've never done it forgetting one could be a disaster. But, with a good book you'll be fine and can ask use the questions the book doesn't cover.
What's different about the fan clutch on the 300 vs the 351W? I've had bunches of the latter off w/o a special tool, but what am I missing?
I've had a lot of problems getting my fan clutch off without using the right fan clutch tool for removal. Theres not enough space between the water pump and the fan clutch to remove it, so the tool helps greatly, even if its just a thin wrench.
Thanks. I use Gear Wrench wrenches which are fairly thin, but probably not thin enough for what you are describing. Good to know.
