6 cyl H head differences ? - Ford Truck Enthusiasts Forums
Old 01-05-2012, 02:36 PM
Ken(Ark) Ken(Ark) is offline
Ken(Ark) is starting off with a positive reputation.
I have heard there is a difference in the 226 48 -51 H heads .
I have a 8HA , 0HA , and a 1HA head but they are on the motors so I can not see the combustion cambers . Is there a difference in cc's ?
I also assume that the G series heads (41-47) wont work on the later motors ?
Old 06-09-2012, 10:30 AM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
My memory is that all H heads have the same combustion chamber and compression ratio. The M head has larger chambers. The G head may bolt on and work on an H engine, but the combustion chamber in the H head is a better design.
Oil pump ford 226h Spartacus1 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 12-25-2015 07:26 AM
1950 Ford F1 226 cylinder head 3twinridges 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 01-21-2015 01:27 PM
New Member - 1951 F-1 1/2 Ton 51f1six New Member Introductions 3 12-28-2014 03:06 AM
O/T Post DP-Tuner 1999 - 2003 7.3L Power Stroke Diesel 4 04-11-2012 04:30 PM
spanked a ps butt ha ha 05harley250 Modular V10 (6.8l) 19 05-16-2007 10:32 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1966, 6cyl, compared, flathead, ford, head, series, straight, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
