Intake Air Heater Relay! - Ford Truck Enthusiasts Forums
Old 01-05-2012, 11:06 AM
Engalwood Engalwood is offline
Engalwood is starting off with a positive reputation.
Is it worth changing this out if bad? Does this help on cold starts that much? We have a few trucks that are kinda hard to start when cold. I reacently repalced the GPR's last year on them. So we know they are ok. And how would a guy check to see if they are bad at all? Thanks abunch AGAIN
Does any body know what the part number for this is? Is it just a reg relay?
Old 01-05-2012, 11:40 AM
thomabb's Avatar
thomabb thomabb is online now
thomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to all
The air intake heater doesn't do anything on startups. I have seen a couple good explanations of the AIH on here, but I can't find one at the moment.
Old 01-05-2012, 11:47 AM
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
Quote:
^^^This is correct. The AIH does not affect start up in any way. It only comes on after the engine is up and running and usually after the glow plugs have cycled off. It's purpose it to minimize excess smoke in cooler ambient temps while idling a cold engine. It really could quality as a sort of emission control item since that is what it's function really is.
Old 01-05-2012, 11:52 AM
thomabb's Avatar
Found it.
FAQ: What is the real purpose of the intake heater, and when does Ford say it will operate normally?
"To reduce white smoke during long idle periods at low ambient temperatures, the PCM will activate the intake air heater. Specific conditions must be present before the heater is activated: "
ambient temperature must be below 0 deg C (32 deg F)
engine oil temperature must be below 55 deg C (131 deg F)
vehicle power must be between 11.8 and 15 volts
parking brake must be applied on manual transmission vehicles
the transmission must be on park or neutral on automatic transmission vehicles
glow plugs must be off
I think this is actually from Rifraff's web site. It has been quoted on these forums often.
Old 01-05-2012, 01:21 PM
Ok. THANK YOU SO MUCH!!!!
Old 01-05-2012, 03:13 PM
Brother Les's Avatar
Brother Les Brother Les is offline
Brother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to behold
As far as I know it is the same as the Glow Plug Relay and same part number. 25.00 At NAPA when asked for under part number GPR109.
As with the specs stated above it is most likely not to come on very often. If your GPR goes out and you need the relay I think that you can move this one over to it (GPR) until you get it replaced.
Old 01-05-2012, 03:32 PM
dagren99 dagren99 is offline
dagren99 is gaining momentum as a positive member of FTE.dagren99 is gaining momentum as a positive member of FTE.
Lots of folks just delete the AIH altogether. Use the leftover port for a boost gauge or just plug it. We deleted the AIH's from our trucks but left the relays in place as "ready to go GPR spares"
Thinking of Trying an exp on one of ours - use the orig GPR to power the GP's on the left and the old AIH relay to power the right side GP's. Hook up the signal lines from the PCM to a small switching relay and then put the "dual GPR's" in parallel so both come on @ the same time. Figure 1/2 the current should increase the relay life. Haven't done it yet but we've mapped it out on an 02 F350 SRW that seems to eat GPR's. (Mainly cause this one gets a lot of starts)
Old 01-09-2012, 10:27 AM
Nice!!! Will keep that in mind!
Old 02-12-2016, 07:52 PM
mrc00l88 mrc00l88 is offline
mrc00l88 is starting off with a positive reputation.
are the part numbers the same for the glow plug relay and the air intake relay?
Old 02-13-2016, 09:20 AM
HKusp's Avatar
HKusp HKusp is offline
HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.
Yes, at Napa GPR109
glow plug issues help lol corman146 6.0L Power Stroke Diesel 5 10-20-2015 10:29 PM
04 F250 Cold Start LOTTS OF WHITE SMOKE Engalwood 6.0L Power Stroke Diesel 10 01-05-2012 10:18 PM
Location of blower fan motor relay on 97 Aersostar? 95TBird Aerostar 6 04-23-2011 06:49 PM
glow plug relay problem phantom 309 1999 to 2016 Super Duty 6 08-12-2010 09:08 AM
Fuel pump (not relay - already checked) need PCM help drudis Explorer, Sport Trac, Mountaineer & Aviator 4 02-12-2010 11:34 AM
Tags
1999, 2003, 73, air, check, diesel, heater, iah, intake, powerstroke, purchase, relay, smoke, turn, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
