adding cruise to 2010 f-150
Old 01-03-2012, 07:07 PM
Faron Mizelle's Avatar
Faron Mizelle
Faron Mizelle is offline
has anyone added cruise to a 2010 f-150 to look like factory
Old 01-03-2012, 09:45 PM
tvsjr's Avatar
tvsjr
tvsjr is offline
You don't need to post multiple times...
Old 01-04-2012, 08:06 AM
Faron Mizelle
wouldn't if someone would answer the first time
Old 01-04-2012, 09:05 AM
msgtord's Avatar
msgtord
msgtord is offline
It's been done on Crown Vics. It may be the same for F150's. I think on the later model Crown Vics, only a steering wheel was needed, then have the dealer flash the ecm.
Crown Victoria, Grand Marquis, Marauder, and Towncar has some threads about adding cruise control. I would think that it would be the same for F150's.
Old 01-04-2012, 12:02 PM
meborder's Avatar
meborder
meborder is online now
it is quite likely that no one knows, which would explain the lack of response.
my work truck has next to nothing for options. manual windows and lock, 2wd, AM/FM only, and we still got cruise. As far as i know, the only options we got is Limited slip, cruise, and the 5.4 (tow package) because we are required to order Flex-fuel vehicles when available.
our are stripped and we still got cruise ... so i'm guessing you have one of the hand-full in the country that don't have it.
people on this forum are pretty nice, lack of response usually indicates lack of usefull input, not lack of interest.
I read your thread right away, but I didn't think that "I don't know" would have been that helpful.
Old 01-04-2012, 12:41 PM
Faron Mizelle
Thanks for the info. The dealers are telling me it can't be done. the cruise control store say they are sure that it can be. Neither will take the steering wheel back if it does not work.
Old 01-04-2012, 11:32 PM
PowerStrokeHD's Avatar
PowerStrokeHD
PowerStrokeHD is offline
Not saying that it can or can not be done, but this is Ford's official stance on the matter...
INSTALLING OEM CRUISE CONTROL SYSTEMS IN NON-EQUIPPED VEHICLES IS NOT RECOMMENDED OR SUPPORTED.
INSTALLING OEM CRUISE CONTROL SYSTEM COMPONENTS IN A NON-CRUISE CONTROL EQUIPPED VEHICLE, IS NOT RECOMMENDED OR SUPPORTED ON ANY FORD OR MERCURY VEHICLE. THE INSTALLATION OF OEM SWITCH EQUIPPED STEERING WHEELS, MODULES, OR ANY OTHER CRUISE CONTROL COMPONENT, WILL NOT ALLOW CRUISE CONTROL OPERATION. MODULE CONFIGURATION REQUIREMENTS ARE DIFFERENT BETWEEN OEM CRUISE CONTROL AND NON-EQUIPPED VEHICLES, AND SHOULD NOT BE ATTEMPTED.
Old 01-05-2012, 12:41 PM
Faron Mizelle
Thanks!! Will probably just go with aftermarket.
Old 01-07-2012, 01:23 AM
michael cook's Avatar
michael cook
michael cook is offline
cruise
that's weird I asked dealer about adding it to mine they said just need new wheel and flash computer !!!! I wonder what is really correct???
Old 01-07-2012, 04:16 AM
Tylus's Avatar
Tylus
Tylus is online now
MMNC (SS)(Ret)
do you guys ever search FTE?
it can be done using 100% OEM components.
1. Look at your steering wheel. There are 2 types
Type 1 has blanks installed
Type 2 has no blanks...so no place to install the switches.
If you have type 1, rejoice. If you have type 2, order/buy a XLT steering wheel that has Cruise Control
2. Buy the Cruise Control switches.
Look around at the online Ford parts places. Better yet, call up Tasca or Tousley Ford and tell them you need the Cruise control switches for the steering wheel.
3. Take new steering wheel (if you had to buy) + switches. Install into truck
4. Take truck down to Dealership and get real cozy with the Service Manager or a Tech
They have to hook up to the Inst Cluster and modify the as built data. basically, they need to look at an XLT truck on the lot that has CC on it. Then take that info and tell your PCM/Inst. Cluster that it too should have CC.
5. Turn on the truck, test the CC out and drive happy.
sorry for the sarcastic tone
Old 01-07-2012, 06:04 AM
michael cook
cruise
My steering wheel has the info /reset/? buttons on left side of wheel nothing on the right side so do I need the xlt wheel also 2011 model
Old 01-07-2012, 09:03 AM
meborder's Avatar
meborder
your info/reset button is on the steering wheel?!?!?
odd ... mine is on the gauge cluster ... must have changed from -10 to -11?
GI8U2racing
01-11-2011 02:59 PM
oem78
08-27-2010 10:14 AM
cghstrojan08
1997 - 2003 F150
03-02-2009 06:59 AM
Quick Reply: adding cruise to 2010 f-150
