High-Idle Mod - Ford Truck Enthusiasts Forums
High-Idle Mod
Old 01-05-2012, 03:04 AM
maverick1701's Avatar
maverick1701 maverick1701 is offline
maverick1701 has a good reputation on FTE.maverick1701 has a good reputation on FTE.
High-Idle Mod
I run a 09 Expedition 4x4 5.4V8 as my work truck for the Sheriffs Office.
I was wondering if there was a way to wire up a high idle switch.
I did a search and only came up with threads about vacuum leaks causing high idle...nothing about making a switch.
There are times (like tonight) where I have to sit at a crime scene for hrs and hrs. I hate to let my vehicle just idle away for that long...especially if Im inside sitting, using electronics etc.
If I had a high-idle switch it would help alleviate the problems that come with excess idle.
Old 01-06-2012, 10:51 PM
96mustangV6 96mustangV6 is offline
96mustangV6 is starting off with a positive reputation.
Are you talking about something like a turbo timer on cars. They run for so long then shut off???
Old 01-06-2012, 11:38 PM
no something I can press to kick up my rpm during times of extended idling....similar to an AIC or ACPM on a powerstroke.
Old 01-07-2012, 06:37 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
What problems are you having with extended idle times now?
I ask only because my 5.4 gasser-equipped E250 sometimes runs in excess of 1.5 hours rear heater, accessory lighting and various power point outlets in use not to mention the FM radio too. For my use haven't noticed any real issues apart from burning fuel without going anywhere.
Old 01-08-2012, 10:54 PM
I don't have any electrical problems with long idle, I was more worried with trying to hold off the mechanical problems that come with extended idling (rod bearing problems and such)
Also in the summer I could knock up the idle and keep my A/C cold on wreck scenes and other crime scenes....because exped A/C sucks in heat at idle
Old 01-09-2012, 05:46 AM
JWA's Avatar
JWA JWA is offline
Maverick I too was worried about potential engine damage due extended idle times but was assured the Modular engines run lean enough at idle while holding sufficient oil pressure this isn't a problem as it would have been with similar V-8 motors.
In my case winter idle times are the most important for my business materials while on a job but the A/C issues I can't speak to at all.
I'm wondering if an outfit like RV or repair shop or snow plow upfitters wouldn't have something that bumps the idle up a bit, perhaps for running inverters or the like? I know they exist but where eludes me too.
Old 01-13-2012, 08:24 AM
JWA's Avatar
JWA JWA is offline
Stumbled across this outfit----links to a throttle control you might be able to use:
VMAC | Brochures | Download VMAC Brochures & Spec Sheets
Old 01-13-2012, 08:48 AM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
I'd think the dealer could turn up the idle via the computer. Wouldn't have to remember to hit the switch that way, only issue would be if they could make it delay say a minute or so, so it wouldn't do it all the time.
Old 04-07-2013, 11:31 AM
ke5eua ke5eua is offline
ke5eua is starting off with a positive reputation.
I know this thread is old, but I am wondering the same thing. I have a 02 F250 with the 5.4 and when doing special events I will be at idle for hours at a time. I understand the truck can handle the idle but my need is I run a 2K inverter so I need to make sure the alternator is charging when idling.
Thank you,
Michael
KE5EUA - Generally I'm an amateur of hams.
Old 04-15-2013, 02:11 PM
jp45601's Avatar
jp45601 jp45601 is offline
jp45601 is starting off with a positive reputation.
I used to have 2004 6.0 diesel & on the Ford powerstroke forum, they told you how to install a switch to add a high idle mod. All you would need is a switch & a couple of pieces of wire. I never done that ,but you could go to the powerestroke forum & maybe you could do to your gas truck?
Building high idle switch for '97 7.3 Alexander Tompkins 1994.5 - 1997 7.3L Power Stroke Diesel 14 12-22-2016 08:36 AM
Building a high idle switch for my '97 7.3 Alexander Tompkins New Member Introductions 0 12-19-2016 07:41 PM
High Idle Mod - Intermittently Blowing Fuse ghott 6.0L Power Stroke Diesel 5 07-24-2016 06:59 PM
Wipers turn on at startup after high-idle mod installed troverman 1999 to 2016 Super Duty 6 12-16-2015 12:20 PM
'05 F150 5.4 DTC P2004 won't go away high_idle 2004 - 2008 F150 1 06-18-2010 11:56 AM
Tags
42, 97, builder, f150, f250, fast, ford, high, idle, jeep, kick, mod, truck, v8, zj
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
