Almost to 100k....To-do/Wish List?
Could someone provide the leaf spring thickness of modified rear B's?
I know my stock X 6/1 leaf pack is 3 3/16" with a spring rate of 2,625lbs
stock B pack is 4/1 leafs with a thickness of 2 1/4" with a spring rate of 3,000lbs
What extra height does adding the 2 leafs from the stock X springs to the B's add?
This will help me narrow down my choices for lifting the rear.
Thanks guys, you've already helped me a bunch.
-Steph
-Steph
I would take the injectors out and have them cleaned and tested or trade them in for something that fits your purposes and put the regulated return on it and tank mods. Also, I believe DP-tuner has a deal where if you buy his reman injectors, you get some free tune upgrades. Talk to them.
Whoops. My bad. Not sure if DP-Tuner does gas. Still, at 100K, I would have the injectors removed and tested. I do this for all my gas vehicles and on my Vette, I take them to CorvetteInjectors.com and they check them every 3 years.
Does anyone have an idea of what could be making the sound in my front passenger wheel well? As I said in my earlier post, as I am coasting/slowing to a stop, I begin to hear a ree ree sound, and also while driving over pot holes etc I hear a clackity clinky noise...almost what I would imagine a shock that lost oil or something, or if it's maybe some bearings/hub part that I'm not aware of
Also has anyone else ever turned on their a/c or have started their X with the a/c in the "on" position and it makes the engine(or some other component under the hood) make a wooofff sound? It's happened a few times, but kinda forgot about it but it happened again the other day because it's been pretty darn warm here in SoCal this january
Thanks, I'm for sure writing all this down. I'm personally wanting to possibly upgrade to mag-tech diff covers, but trying to see if they are more for show or does the extra capacity truly justify getting them.
Can anyone provide part #'s for the following and any other items I'd possibly need:
-4wd ball joints/bearing/ extras?
-ANY OTHER SUSPENSION/STEERING componets that I might as well checkout while the newer leafs are being put on.
I think I've decided to go with:
Front: V's along with Icon 3" Hanger system
Rear: mod B's along with the provided 4" block from the Icon kit
4-Icon monotube shocks for 3-6" lifts(would upgrade to res's later)
Rear 350 sway-bar
Beefier front sway bar....From a 350 or Hellwig?
Traction/ladder bars...will ones for the trucks also fit the X?
#29
I was told V's and regular B's require a 3.5" rear block to stay fairly level.
The Icon 3"...will that serve to raise the front further than the stock hangers?
I ask because I was also told when you use stock V's and the Modded B's will use the stock block to keep it level. I don't know the height of the stock block, but if you add 3 with the Icon, if the stock block is less than 1", you may not end up with a level truck - you may have a front-up stance.
I'm sure it would help if I knew the stock block height...can someone make sure the 4" block will give it a rear-up stance or at least level?
#30
Wait...hold on.
I personally do not mind a "slightly" nose high stance because I do already have Airlift rear airbags, I can always full those a little or later on decide if I need a 5" block.......no matter what however I need rear blocks with bump stop tangs because that is the only way to mount the rear airbags...slightly different then the trucks whose are attached directly onto the leaf pack and frame.
Current stance:
front 38.75"
rear 40.25"
-With V's I'm looking at hopefully 1-2" lift
plus the 3" Icon hanger I'm looking at a total of 4-5" that brings the front up to approx 42ish-maybe as high as 44"
Now with the rear I'll be using the 4" block w/tangs included from Icon
and that brings the rear already to 42.25ish" + whatever little extra from doing the mod B's...and that's about 43ish in the end I'm thinking.
