Looking for heater core
Old 12-28-2011, 10:31 PM
MARC's Avatar
MARC
MARC is offline
For 59 f100. Any ideas. None at obsolete or sac vintage ford
Thx Marc
Old 12-29-2011, 06:42 AM
spurredon's Avatar
spurredon
spurredon is offline
I don't think you will find one out there that is just plug and play. If money is no object, you can find a core that is close to the same size and reuse the tanks. I ended up getting one for a newer truck and had to get a little creative with heater hose. I can't remember with year is close but I will try to find my notes and get back to you. I spent a couple weeks off and on trying to find one. I got one that had short straight tubes coming off the tank, used short pieces of heater hose to connect to to original tubes from the original tank that I cut off to stick thru the firewall. It looks great under the hood, you can't see a difference. You can only see the change if you lay on the floor of the truck and look up between the heater and the firewall. It is very functional.
Old 12-29-2011, 10:50 AM
Tomget's Avatar
Tomget
Tomget is offline
This kinda stuff appears on ebay from time to time.
Old 12-29-2011, 03:04 PM
57icebox's Avatar
57icebox
57icebox is offline
Old 12-31-2011, 05:40 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
B7TT-18476-A (replaced B7C-18476-B & B7C-18476-C) .. Heater Core / Obsolete
Applications: 1957/60 F100/700 / No Ford Dealer or obsolete parts vendor has any.
Any radiator shop can recore a heater core.
Old 01-01-2012, 01:25 PM
bruman's Avatar
bruman
bruman is offline
Making an heater core!
Hi!
I,m new to this site and very excited about finding it.
I have an idea about making a heater core by using PEX tubing & coiling it up inside the heater box, similar to the concept of burying tubing in concrete slabs in new houses & running hot water thru it, & tying it into my heater hoses W/ a throttling valve to control the temp.
It would be really inexpensive to make & it would reaaly be nice to have heat again!!
What do you'all think?
Bruman
1960 F-100
'86 302 w/ AOD
self contained electronic dist.
mild cam
3.0 gears
& hopefully a crown vic suspension soon!
Old 01-01-2012, 09:25 PM
Bill W's Avatar
Bill W
Bill W is offline
try performance radiator on Ft lowell Marc. they did a great job on mine.
Old 01-01-2012, 10:02 PM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
Marc; Do you have your old core if you do they really are not that hard to repair (torch solder and flux) unless it froze and split multiple rows in the core, if the tank is cracked that can be soldered as well. You can us a bicycle tube to pressure test it. Any radiator shop can re-core it!
Good luck
Old 01-05-2012, 12:12 AM
MARC's Avatar
MARC
MARC is offline
Bill, what did they charge to rebuild the core?
Old 01-05-2012, 04:54 AM
3414's Avatar
3414
3414 is offline
Hello there,
The PEX tubing does not have the heat transfer capability of the standard heater core. At best you will warm the air a little bit, but not enough to get comfortable. Your best bet is to find a good used core or a repairable one. A heater core has a large surface area for both the coolant and the air that you would need well over a hundred feet of PEX tubing to replicate.
Originally Posted by bruman
Hi!
Bruman
1960 F-100
'86 302 w/ AOD
mild cam
3.0 gears
Old 02-11-2012, 03:05 PM
1960fordf350's Avatar
1960fordf350
1960fordf350 is offline
I've found a heater core today that is almost a direct fit. Murray's/O'Reilly auto parts
Part # 39801. Its aluminum, not brass. $22.95 plus tax.
They let me search their radiator book that was on the shelf. They had the core there too.
Old 02-11-2012, 03:51 PM
bruman's Avatar
bruman
bruman is offline
Hey Hoss, I can't thank you enough!!! This is great news. I'm going to call the O'Reilly store just up the street & see if they have one & I'll pick it up today.
Thanks again, Bruman...
Old 02-12-2012, 03:09 PM
1960fordf350
I was just looking at the box, my bad, add a 0 to that number 398001
Old 02-12-2012, 07:49 PM
bruman's Avatar
bruman
bruman is offline
Thanks again! I just picked it up about 5 minutes ago, $22.95.
Bruman!!
Old 02-13-2012, 11:21 AM
GB SISSON's Avatar
GB SISSON
GB SISSON is offline
Where I come from, when you end up on your back on the floor of your truck looking up between the heater and the firewall it's considered dys- functional....
Andy_H
06-12-2007 12:18 AM
FloridaFord250
1999 to 2016 Super Duty
05-07-2006 07:25 AM
maxwgn
Aerostar
11-11-2005 11:59 AM
DuckRyder
11-07-2003 12:25 AM
cmoore
12-14-2002 08:42 AM
Quick Reply: Looking for heater core
