Windshield washer hose - what size? - Ford Truck Enthusiasts Forums
Old 01-04-2012, 03:00 PM
Myfreeford's Avatar
Myfreeford Myfreeford is offline
Myfreeford is starting off with a positive reputation.
Does anyone know the inside diameter of the windshield washer hose that was used from the washer fluid tank to the spray heads on the 75 f250?
Thanks.
Old 01-04-2012, 06:22 PM
bamaf150's Avatar
bamaf150 bamaf150 is offline
bamaf150 is gaining momentum as a positive member of FTE.
Quote:
Thanks.
I just replaced mine a few weeks ago with a kit from Dennis Carpenter, I needed the plastic fitting on the firewall so I ordered the hose as well; measured with a tape measure it looks like 3/16" ID, this is the hose from the tank to the fitting on a '76 F-100
Windshield washer hose Glenn54 1987 - 1996 F150 & Larger F-Series Trucks 3 12-14-2016 11:47 AM
Windshield washer David Popp Air Intakes, Air Filters & Ram Air 0 04-24-2016 02:20 PM
Windshield Washer Adjustment - 2003 E250 Done_Deal 1968-2013 Full Size Vans 5 04-07-2014 07:53 AM
1978 Part # needed saxtonj 1973 - 1979 F-100 & Larger F-Series Trucks 2 01-25-2014 07:39 PM
Low Water Pressure on Windshield Washer? johnmel59 1961 - 1966 F-100 & Larger F-Series Trucks 11 01-15-2014 10:59 PM
Tags
1997, 2006, 2007, escape, f150, fitting, fluid, ford, hose, replacing, size, sprayer, tube, tubing, washer, windshield, wiper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
