Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Missouri Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Missouri Chapter Join Chapter , Leader:tcbofade
  #1 (permalink)
Old 01-04-2012, 02:12 PM
Woodyp's Avatar
Woodyp Woodyp is offline
Garage is empty, add now
Woodyp is starting off with a positive reputation.
Where to find Ospho in Kansas City Area
Does anyone know where to find Ospho rust converter in the Kansas City area? Or maybe Picklex 20 or Jasco prep and prime?
__________________
71 F100 390 Auto 2wd
68 F100 390 4 speed Project: In The Red
Enough parts to build another F100 except frame, title, and headlight switch.
73 Mustang convertible 351w Auto.
Some more I won't mention here.
  #2 (permalink)
Old 01-04-2012, 03:02 PM
cyclopsblown34's Avatar
cyclopsblown34 cyclopsblown34 is offline
cyclopsblown34 is gaining momentum as a positive member of FTE.
My local Sherwin Williams store orders it in for me. it's around 30.00 for a quart through them.
__________________
1966 Triumph GT6 Driveline undetermined
66 Buick Skylark Special convertible...
1975 F250 4x4
.Project overwhelmation...yes I know it is not a real word, but more a feeling. Thanks Rich
  #3 (permalink)
Old 01-04-2012, 06:05 PM
Woodyp's Avatar
I stopped in Sherwin Williams near me earlier today and they were clueless. I've found it on Amazon for $15.20 per qt or a gallon form Jamestown Distributor for $50 including shipping. Ospho
I just want it now!
Thanks for the reply.
__________________
  #4 (permalink)
Old 01-04-2012, 09:55 PM
77&79F250's Avatar
77&79F250 77&79F250 is offline
Workaholic
1978 Ford F-250
My Garage
77&79F250 is a splendid one to behold77&79F250 is a splendid one to behold77&79F250 is a splendid one to behold77&79F250 is a splendid one to behold77&79F250 is a splendid one to behold77&79F250 is a splendid one to behold77&79F250 is a splendid one to behold
Ospho: Smaller Quantities can be found at some:
ACE Hardware Stores (Check ACE Warehouse if local store doesn't have it)
True Value Hardware
Do-It-Best Hardware
Handy Hardware
Orgill, Inc.
*Sherwin Williams
Duron Paints & Wall Coverings
Lancaster
Pickelx20: Also used by thousands of auto restorers in & outside USA along with a lot of auto body paint shops. Time to hit the yelllow pages.
Jasco prep and prime: Jasco products can be found at most Lowes, Home Depot and ACE Hardware stores nationwide. Check with your local hardware store or home improvement supply.
__________________
77&79 F250 Rich & Penny
77 351M auto, factory a/c add a leaf/33x12.50's
78 (79 headlights) 460 4 spd, factory a/c and 35's
79 351M 4spd 6" Skyjacker Edelbrock-Holley-Hedman 35's
99 Ranger 4x4 Ext Cab Flareside V-6, 98 Expedition EB 4x4
71 Bronco 302 35" Boggers 5.58 gears spool/locker
  #5 (permalink)
Old 01-05-2012, 04:20 PM
Woodyp's Avatar
Yeah, 77&79F250, that's great info from the website but you forgot the previous sentence that states, "Companies buy in bulk and distribute to their stores when the stores request Ospho." After calling and visiting many ACE hardware in the last few days I finally found an ACE hardware store that took the initiative to actually look it up and ordered it. they'll have 4 gallons in stock on Tuesday for $27 per gal at 95th and Mission.
and I did find Jasco products for sale at Lowe's but not the Prep & Prime.
I've called and visited 4 auto paint supply stores and none of them had ever heard of picklex 20.
It amazed me at how little the auto paint stores knew about rust treatment and understood the difference between Rust encapsulators and rust converts.
__________________
  #6 (permalink)
Old 01-05-2012, 05:58 PM
77&79F250's Avatar
Workaholic
1978 Ford F-250
My Garage
Just thought it might help sorry it seems not to of......good luck locating the stuff and not paying a arm and a leg for it.
All the products you are looking for sound like good stuff?
__________________
  #7 (permalink)
Old 01-06-2012, 08:55 AM
If you need any tech help on the OSPHO and its use in restoration, they have an expert you can email. He's helped me out a bunch with how to use it properly to remove rust and then topcoat it with epoxy. he's been using it for at least 25 years with no problems.
__________________
1975 F250 4x4
  #8 (permalink)
Old 01-07-2012, 05:26 PM
Woodyp's Avatar
Hey 77&79F250 hope I didn't sound snootie I was just frustrated with the lake of help on the website.
__________________
  #9 (permalink)
Old 01-07-2012, 05:32 PM
Woodyp's Avatar
cyclopsblown34 Thanks for the info, when you used it how did you apply it? I've seen it done with squirt bottles, paint brushes and red Scotch bright pads. Tell me about your experiences.
__________________
  #10 (permalink)
Old 01-07-2012, 08:31 PM
77&79F250's Avatar
Workaholic
1978 Ford F-250
My Garage
Its all good.....
__________________
  #11 (permalink)
Old 01-07-2012, 08:43 PM
I apply it in approximate one square foot sections with a brush and work it with a wire brush or wheel on a drill or grinder while still wet then wipe it off and let it dry. If there's any black spots the next day, I repeat the procedure til no more black spots show up, indicating the rust has been eliminated. On pitted rust, it usually takes a couple days to eliminate the rust on a typical ponycar roof.
Just prior to welding on or applying epoxy primer to a treated surface, I clean it with a dry scotchbrite pad. The dried OSPHO gives the surface some protection from rust until you remove it. Use a respirator with paint type filters when working the wet OSPHO. Use a dust mask or respirator when removing the dried OSPHO.
__________________
1975 F250 4x4
  #12 (permalink)
Old 06-11-2012, 08:15 PM
hussey hussey is offline
hussey is starting off with a positive reputation.
Hey,
I was doing a google search for Picklex in KC and saw your post. I ended up ordering a gallon since it's so much cheaper by the oz. I'll have more than I need and was sharing with a friend and would like to try and sell the rest. Would you be interested in some?
My name is Ryan, I can be reached at 913-375-2634 or husseyrj@gmail.com
Tags
20, ace, buy, depot, hardware, home, jasco, locations, ospho, picklex, picklex20, powered, prep, prime, ranger, store, true, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
