Key switch actuator
on
1 Post
Key switch actuator
Anyone have the little dowel pin fall out of the upper ignition actuator? My truck would start but not turn off. I was expecting to have one of the two plastic parts broken, but when I got the steering column apart all I found was that the little dowel pin fell out.
I've glued it back in an hopefully it will go another 202K before breaking again.
Received 3,090 Likes
on
The following users liked this post:
on
1 Post
I don't know if this will help any or not......
exploded view for the 1995 Ford F250 tilt | Steering Column Services
How hard was it to get into the plastic pieces? It looks to me you have to remove a ton of stuff to get at it.
Last edited by Ford4Life7.3; 08-25-2012 at 03:59 AM. Reason: Iphone+fat fingers=******
The hardest part was getting the snap ring off the shaft with no snap ring pliers. There are two star bolts on the side, and you have to ajust the tilt and pull the coulom apart at the same time. Make sure you turn your key at the same time to. The plastic piece has gears on it and runs on the key cyl.
