i can not get my truck to start after injector replacement. It fired right away then died. now it turns over but nothing happens. any help would be greatly appreciated. 01 f-250 7.3
Do your batteries have a good charge on them?May need to hook the charger up to them.May have drained the HPOP as well.I bet it will start when you get good oil pressure to the injectors.
i recharged the batteries and it still wont start. how do i get the hpop refilled?
There's an allen head plug on the top of the HPOP reservoir. Remove it and fill it up. Takes almost a qt. If it's within an inch from the top, that's close enough.
I know when I pulled/replaced my injectors it took enough cranking to make me start thinking I mucked it up. Almost 2 bat charges worth. I did not top of the HPOP....
ok i've charged the batteries twice since yesterday morning. i cranked on it til i started worrying about the starter. not solid cranking but for 10-20 seconds and then a short break in between. still nothing, not even a sputter. the oil resevoir is just a little under completely full. is there anything else i can do? do i need to bleed the air out of the lines? i havent tried the 50 cent thing yet.
