Dying Starter Solenoid? - Ford Truck Enthusiasts Forums
Old 01-04-2012, 10:49 AM
Rose Clifford's Avatar
Rose Clifford Rose Clifford is offline
Rose Clifford has a great reputation on FTE.Rose Clifford has a great reputation on FTE.Rose Clifford has a great reputation on FTE.Rose Clifford has a great reputation on FTE.
Before I order a new one, just want to double check with you guys. When it's cold (30deg or lower) my starter doesn't always catch the flywheel. It will spin, or just click and I need to tap on the solenoid to get it to work. New batteries and new alternator 3 months ago.
How much is a solenoid? I have a 2 bolt OSGR starter
Old 01-04-2012, 11:30 AM
I'm having trouble finding a part # for the starter solenoid...I hope I don't have to get a whole new starter. Mine cranks like a ******* when it works!
Old 01-04-2012, 12:23 PM
1996pwrstrk's Avatar
1996pwrstrk 1996pwrstrk is offline
Wrench Party Assistant
1996pwrstrk has a great reputation on FTE.1996pwrstrk has a great reputation on FTE.1996pwrstrk has a great reputation on FTE.1996pwrstrk has a great reputation on FTE.1996pwrstrk has a great reputation on FTE.
You are talking about the solenoid on the starter not the relay on the inner fender ? Did you check and make sure the starter bolts were tight ? I would also check your ground wires . I don't know if they make a seperate solenoid for are starters but I have usually found that when you have to tap on the starter to get it to spin its starter time.
Old 01-04-2012, 12:32 PM
carltonwebb's Avatar
carltonwebb carltonwebb is offline
carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.
if its the 03 in the signature, I do not think they have the fender mounted solenoid on them. I would take it off and get it gone through at the rebuild shop if the mounting bolts are tight.
Old 01-04-2012, 12:35 PM
Quote:
I haven't checked ground wires...it only happens when it's cold.
I turn the keep and get the WTS light
First try starting, the starter will spin and not engage the motor
Second try it will just click as if the batteries are too low
Tap the starter/solenoid
Starts up fine
The starter was slightly loose a while ago but I've since tightened it up. Out of curiosity though how would this affect it not activating when the key is turned?
The connections should all be tight. Last winter I had a problem with it spinning and not engaging the motor.
Old 01-04-2012, 12:37 PM
Quote:
It is the 03 in the sig. Tapping the starter makes me think that's the issue, not the relay.
Old 01-04-2012, 12:44 PM
Quote:
With the bolts loose on the starter you loose good ground ,the starter gear can loose contact with the ring gear and just spin and not turn the engine over. I would pull it and have the starter checked.
Old 01-04-2012, 12:46 PM
You are right. It sounds like the solenoid, a burr on the bendix drive, or possibly a bad spot on the armature by what you are describing or possible a little of all 3.
You probably know about this place but just in case. I ordered one for my 2000 from here and it works great> They may have the solenoid for u as well.
http://www.db-starter-alternator.com/
Old 01-04-2012, 12:52 PM
carltonwebb thank you for that info I thought they all had the relay on the inner fender.
Old 01-04-2012, 12:54 PM
I learned it here from someone else. I think 2002 is the 1st year without it. My 2000 and 2001 both have it.
Old 01-04-2012, 01:07 PM
Ford started using a "2 bolt" OSGR starter on 2/27/01, before then they were "3 bolt" starters.
I'll try snugging everything up tonight....why would it only happen in the cold though?
Old 01-04-2012, 07:45 PM
crop harvester crop harvester is offline
crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.
most starters weak point is the solinoid or the pinnion drive , yours could be the solinoid , but it could be just really sticky or rust and dry where the pinnion slides on the armature shaft,I use to rebuild starters for a hobby
Old 01-05-2012, 06:10 AM
Quote:
Do you know where I can get a new solenoid for the 2-bolt 2002-2003 starter?
Old 01-05-2012, 07:25 AM
joeyd61's Avatar
joeyd61 joeyd61 is offline
joeyd61 has a great reputation on FTE.joeyd61 has a great reputation on FTE.joeyd61 has a great reputation on FTE.joeyd61 has a great reputation on FTE.joeyd61 has a great reputation on FTE.
when mine went out, i was told that you couldnt buy just the solinoid..had to buy a complete starter
Old 01-05-2012, 09:10 AM
empiretc's Avatar
empiretc empiretc is online now
empiretc is a name known to allempiretc is a name known to allempiretc is a name known to allempiretc is a name known to allempiretc is a name known to allempiretc is a name known to all
just replaced the starter (and alternator) yesterday. damn, what a difference.
if you are going through the trouble, just replace the entire thing. it's a PITA.
Solenoid, starter or ignition?? fyredude 1999 to 2016 Super Duty 15 07-15-2016 01:56 AM
1992 Ranger Starter and Starter Solenoid Clarabelle Ranger & B-Series 11 12-16-2015 02:06 PM
96' F350 Crew cab 460 5 spd Solenoid bad? cityjack 1987 - 1996 F150 & Larger F-Series Trucks 2 02-09-2014 08:49 PM
Starter Life? pwauburn Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 12-09-2011 10:07 AM
Won't start, new starter, starter solenoid, battery, and alternator BigSouth 1987 - 1996 F150 & Larger F-Series Trucks 3 02-15-2011 03:34 PM
Tags
2001, 2002, 60, 68l, 73, 99, diesel, dying, f250, f350, ford, part, problems, relay, solenoid, starter, weak
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
