Dying Starter Solenoid?
Old 01-04-2012, 10:49 AM
Rose Clifford's Avatar
Rose Clifford
Rose Clifford is offline
Before I order a new one, just want to double check with you guys. When it's cold (30deg or lower) my starter doesn't always catch the flywheel. It will spin, or just click and I need to tap on the solenoid to get it to work. New batteries and new alternator 3 months ago.
How much is a solenoid? I have a 2 bolt OSGR starter
Old 01-04-2012, 11:30 AM
Rose Clifford
I'm having trouble finding a part # for the starter solenoid...I hope I don't have to get a whole new starter. Mine cranks like a ******* when it works!
Old 01-04-2012, 12:23 PM
1996pwrstrk's Avatar
1996pwrstrk
1996pwrstrk is offline
You are talking about the solenoid on the starter not the relay on the inner fender ? Did you check and make sure the starter bolts were tight ? I would also check your ground wires . I don't know if they make a seperate solenoid for are starters but I have usually found that when you have to tap on the starter to get it to spin its starter time.
Old 01-04-2012, 12:32 PM
carltonwebb's Avatar
carltonwebb
carltonwebb is offline
if its the 03 in the signature, I do not think they have the fender mounted solenoid on them. I would take it off and get it gone through at the rebuild shop if the mounting bolts are tight.
Old 01-04-2012, 12:35 PM
Rose Clifford
I haven't checked ground wires...it only happens when it's cold.
I turn the keep and get the WTS light
First try starting, the starter will spin and not engage the motor
Second try it will just click as if the batteries are too low
Tap the starter/solenoid
Starts up fine
The starter was slightly loose a while ago but I've since tightened it up. Out of curiosity though how would this affect it not activating when the key is turned?
The connections should all be tight. Last winter I had a problem with it spinning and not engaging the motor.
Old 01-04-2012, 12:37 PM
Rose Clifford
It is the 03 in the sig. Tapping the starter makes me think that's the issue, not the relay.
Old 01-04-2012, 12:44 PM
1996pwrstrk
With the bolts loose on the starter you loose good ground ,the starter gear can loose contact with the ring gear and just spin and not turn the engine over. I would pull it and have the starter checked.
Old 01-04-2012, 12:46 PM
carltonwebb
You are right. It sounds like the solenoid, a burr on the bendix drive, or possibly a bad spot on the armature by what you are describing or possible a little of all 3.
You probably know about this place but just in case. I ordered one for my 2000 from here and it works great> They may have the solenoid for u as well.
http://www.db-starter-alternator.com/
Old 01-04-2012, 12:52 PM
1996pwrstrk
carltonwebb thank you for that info I thought they all had the relay on the inner fender.
Old 01-04-2012, 12:54 PM
carltonwebb
I learned it here from someone else. I think 2002 is the 1st year without it. My 2000 and 2001 both have it.
Old 01-04-2012, 01:07 PM
Rose Clifford
Ford started using a "2 bolt" OSGR starter on 2/27/01, before then they were "3 bolt" starters.
I'll try snugging everything up tonight....why would it only happen in the cold though?
Old 01-04-2012, 07:45 PM
crop harvester's Avatar
crop harvester
crop harvester is offline
most starters weak point is the solinoid or the pinnion drive , yours could be the solinoid , but it could be just really sticky or rust and dry where the pinnion slides on the armature shaft,I use to rebuild starters for a hobby
Old 01-05-2012, 06:10 AM
Rose Clifford
Do you know where I can get a new solenoid for the 2-bolt 2002-2003 starter?
Old 01-05-2012, 07:25 AM
joeyd61's Avatar
joeyd61
joeyd61 is offline
when mine went out, i was told that you couldnt buy just the solinoid..had to buy a complete starter
Old 01-05-2012, 09:10 AM
empiretc's Avatar
empiretc
empiretc is offline
just replaced the starter (and alternator) yesterday. damn, what a difference.
if you are going through the trouble, just replace the entire thing. it's a PITA.
Quick Reply: Dying Starter Solenoid?
