I only have high on the controls to the fan on my HVAC panel. It's got a new blower motor from july. Possible vacume leak? Where would I start to look for one of those,behind the HVAC control panel?
does your switch that controls where the air comes out switch from dash vents to defroster vents etc...? If not I had the same issue and checked all the vacuum lines and had no leaks then I tested the switch itself and found that the outlet that control the dash vents wasnt holding pressure so I replaced the switch and now everything works..
Out by the blower motor is the resistor that controls your speeds. Everything except high goes through it. Its two 8 mm headed screws and one connector with 4 wires in it and is directly to the right of the blower motor looking towards the back of the truck. That is probably your issue and it is cheap. Here is a link to give u a reference as to what it looks like.
