Fuel Tank Selector Switch 86 F250 7.5 - Ford Truck Enthusiasts Forums
Old 01-03-2012, 06:56 PM
Hydropower Luke Hydropower Luke is offline
Hydropower Luke is starting off with a positive reputation.
Hi and thanks for the site. I'm a rookie and this is my first post. She is an 86 f250 7.5 two wheel drive. Just bought it and everything worked but the rear tank. Figured it was the selector switch. Took the dash apart and tried switching. Truck ran for a few and then died. Went back to the front tank. Now front tank not working, no gas guage in either direction too! I knew I should have left it alone.... Pulled switch out and got to 6 plug connector. Burned ground wire (black) and lots of bad wiring behind the switch. Cleaned up wiring and checked switch, no start, no gas guage. Checked fuses at block, none blown. Checked fuseable links at solenoid, all are good. Got proper wiring diagram, made sure all wires were in the correct plug position in switch. Checked for power to switch. Only get power to switch when starter is cranking and then shortly after I stop cranking . Otherwise there is no full time power to this switch. It looks like there should be power to this switch as soon as the key is on but my fuse block doesn't seem to have a #15 10 amp socket. I am baffled how the gas guage gets power from the switch. Is it through the tank selector valve switch? Can anyone give me an idea what to do next here. Its a really pretty truck with no rust. Any ideas guys?? Remember, its a 460, not fuel injected with a electrical tank selector valve.
Old 01-03-2012, 08:34 PM
ArdWrknTrk ArdWrknTrk is offline
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
Welcome to the forum Luke!
This diagram?
The power goes directly to the relay when Cranking.
When in Run the power travels through the inertia (safety) switch and the oil pressure cut out controls the relay.
If you have no oil pressure, or that wiring is damaged the truck will not continue to run.
BTW, this post should be in the 80-86 forum, not the 87-96.
Perhaps a moderator will move it.
You may get better answers there.
Old 01-04-2012, 05:18 PM
My selector switch has 6 wires, two R, one R&B two B&W and one Black. However your diagram looks like it has only three? Other than that it looks more correct than the one that I have that shows 6 wires going to the selector switch. I think I will follow yours, it has no fuses at the fuse box and that had me baffled as all my fuses tested good. I am leaning towards the selector valve or the yellow fuse link as I tested the blue one . I need to get some time to pull it into my warm garage, but like most 460's these days, its not my daily driver. Thanks for the reply and also for pointing out the wrong year forum for me. Maybe a moderator will take pitty on a first timer and move me to the correct decade. I may not need it now though thanks to you getting me this diagram. I will let you know if I get it running. Thanks Jim!
Luke
Old 01-04-2012, 05:47 PM
pedant
There is this diagram;
http://www.ford-trucks.com/forums/at...6&d=1218602346
And this I quote from our resident Ford parts counter guru Bill.
Quote:
Originally Posted by NumberDummy View Post
D5TZ-9189-B .. Fuel Tank Selector Valve
6 ports / Marked: E57B-9F271-BA
Fits many different models and engine sizes 1985/91.
fuel tank selector switch ef150owner 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 14 07-19-2016 02:19 PM
FRONT GAS TANK NOT WORKING 1badshovel Fuel Injection, Carburetion & Fuel System 6 02-01-2013 03:44 PM
duel tank, not switching between tanks Dean Ledgerwood 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 02-16-2012 11:35 AM
85 f250 selector/pump/sender wiring trouble! archangel Electrical Systems/Wiring 15 03-07-2004 02:07 AM
85 f250 fuel selector valve/pump/sender trouble archangel Fuel Injection, Carburetion & Fuel System 14 01-31-2004 12:09 PM
Tags
1979, 1996, 250, 96, ac, diagram, econoline, explorer, f250, ford, fuel, knob, parts, selector, system, tank
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
