2 gauge battery charge cable and alternator pigtail write up - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 04-09-2013, 05:10 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud of
Quote:
Originally Posted by rpenterics View Post
Bringing up an old thread but trying to get an answer...in your write up you say:
Any issues/concerns with eliminating the fusible link protection on this wire?
Absolutely no issues. I'm no longer running a fusible link or a fuse of any kind on the charge cable. Works just fine.
  #32
Old 06-12-2013, 11:00 AM
ProjectDually's Avatar
ProjectDually ProjectDually is offline
ProjectDually is a splendid one to beholdProjectDually is a splendid one to beholdProjectDually is a splendid one to beholdProjectDually is a splendid one to beholdProjectDually is a splendid one to beholdProjectDually is a splendid one to beholdProjectDually is a splendid one to behold
I know this post hasn't been bumped in a while, but did you have to take anything to the starter? or just from the
alternator->"fuse block"->starter solenoid?
I got a 250A alternator, I plan on running a bunch of lights, and a nice sound system, and the ability to run more from my 12V without straining/ killing off the batteries constantly..
So should I just get a bigger AMP Mega fuse than what you have? The 2GA and the copper lugs are easy to acquire locally, solder pellets are tough to find around here though..
  #33
Old 06-12-2013, 12:21 PM
I bumped up to a 250a also. Jump up to a 1/0 charge cable and either run no fuse like I am now or you will need like a 300a fuse and make sure there is no resistance in the fuse.
All you need is the charge cable and it wouldn't hurt to build a ground cable to go from the alt case to the negative on the batt using the same size cable as the charge cable. Nohing needs to be run to the starter or anything.
Multifunction switch write up strokin'_tatsch 1994.5 - 1997 7.3L Power Stroke Diesel 20 02-28-2017 06:55 AM
The rebuild of my SD! strokin'_tatsch 1999 - 2003 7.3L Power Stroke Diesel 256 04-03-2015 08:57 AM
mechman alternator installed... finally... strokin'_tatsch 1994.5 - 1997 7.3L Power Stroke Diesel 9 08-26-2013 03:31 AM
Murff Racing T4 mounting kit(pics!!) strokin'_tatsch 1994.5 - 1997 7.3L Power Stroke Diesel 56 02-17-2012 01:44 PM
Multifunction switch write up strokin'_tatsch 1987 - 1996 F150 & Larger F-Series Trucks 7 02-12-2011 11:48 AM
Tags
alternator, battery, cable, charge, charger, charging, cord, excursion, f350, ford, gauge, kit, pigtail, size, truck, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
