2 gauge battery charge cable and alternator pigtail write up - Page 2 - Ford Truck Enthusiasts Forums
Old 01-04-2012, 02:30 PM
bad12jr's Avatar
bad12jr bad12jr is offline
bad12jr is gaining momentum as a positive member of FTE.bad12jr is gaining momentum as a positive member of FTE.
Reps sent Travis. I have fusion ones with the solder already in them. Waiting on one flag battery cable ends and lugs for the ground wires.
Old 01-04-2012, 09:09 PM
pjwoolw's Avatar
pjwoolw pjwoolw is offline
pjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to all
This one is definitely worth an atta babe Travis! Well done!
I'm out of ammo for ya though.
Old 01-05-2012, 12:56 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Travis, your the man! With my 200 amp mean green alternator sending juice back to my camper that has six batteries to run a freezer and refrigerator, this is exactly what I need to do. Reps sent, I'm glad I'm able to.
Old 01-05-2012, 07:38 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
Quote:
Yeah I tried too, but I'm in a timeout....
Old 01-05-2012, 01:42 PM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is offline
Brown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud of
Yep, no reps from me either...
Old 01-05-2012, 03:46 PM
strokersace's Avatar
strokersace strokersace is offline
strokersace has a very good reputation on FTE.strokersace has a very good reputation on FTE.strokersace has a very good reputation on FTE.
Nice job Travis.
Questions for you as I'm kinda dumb about this: What would be the advantage or disadvantage to going straight from the fuse holder to the battery instead of thru the solenoid? Do you even need to go thru the solenoid? If not, what are the risks (what do you lose) by bypassing it?
I'm wanting to upgrade all my charge wires at some point and put on a bigger alt.
Old 01-05-2012, 04:14 PM
joe_13894 joe_13894 is offline
joe_13894 is gaining momentum as a positive member of FTE.joe_13894 is gaining momentum as a positive member of FTE.
Quote:
I put in the feed for my camper directly from the alternator and left the wiring to the truck battery alone. I figured that the bulk of the high current charging would be to the camper then I should just take the heavy wire to the alternator directly.
I also used a lift gate plug for the pigtail to the camper. It is the size of a truck 7 pin connector but has two giant pins in it. Since I've done that I've never had a problem with low batteries in the camper.
Old 01-05-2012, 04:52 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud of
Quote:
Originally Posted by strokersace View Post
Nice job Travis.
I ran the charge cable to the solenoid on both of my trucks b/c that's where the bulk of my accessories are drawing from, not straight from the batteries. As you can tell in the pic of my solenoid, I have quite a few aftermarket things run to the solenoid for power. Not sure how much difference there would be running straight to the battery.
It is cleaner to just run the wire to the solenoid so you don't have another wire on the battery and I tested last night with everything running on my truck last night. Voltage at the solenoid and battery voltage are exactly the same with everything running. I doubt there'd be any difference running straight to the battery.
Old 01-05-2012, 08:55 PM
That sounds good Joe but I don't fully understand. Did you splice into the charging wire that Travis is talking about? Does this lift gate plug fit the standard RV plug? Can the RV positive wire handle the higher charge? I am interested in Travis's mode and your idea, tell me more! The combination of these can really help me out and make that 200 amp alternator of mine do some serious work.
Old 01-05-2012, 11:04 PM
I did a post with pictures of the install on RV.net:
RV.Net Open Roads Forum: Truck Campers: Heavy gauge charging systems
Old 01-05-2012, 11:26 PM
Awitte58's Avatar
Awitte58 Awitte58 is offline
Awitte58 has a good reputation on FTE.Awitte58 has a good reputation on FTE.Awitte58 has a good reputation on FTE.
Very good info as well Joe!
Old 06-18-2012, 10:02 PM
The Bronc The Bronc is offline
The Bronc is starting off with a positive reputation.
When you wire the chage cables and wires that way does the stock amp gauge still work?
  #28
Old 06-18-2012, 10:57 PM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
Quote:
It should.
What he did with the shortened wire was eliminate a silly wire run that read from the same lead.
  #29
Old 06-19-2012, 01:26 PM
Quote:
Originally Posted by Talyn View Post
It should.
Exactly. Wiring it in this way, everything still works exactly how it did before.
  #30
Old 04-09-2013, 03:52 PM
rpenterics's Avatar
rpenterics rpenterics is offline
rpenterics is gaining momentum as a positive member of FTE.
Quote:
Bringing up an old thread but trying to get an answer...in your write up you say:
Quote:
What your going to end up doing is rather than having the yellow wire running all the way to the starter solenoid, put a ring terminal connector on it and attach it to the charge cable lug on the alternator
Any issues/concerns with eliminating the fusible link protection on this wire?
Multifunction switch write up strokin'_tatsch 1994.5 - 1997 7.3L Power Stroke Diesel 19 Yesterday 05:57 AM
The rebuild of my SD! strokin'_tatsch 1999 - 2003 7.3L Power Stroke Diesel 256 04-03-2015 09:57 AM
mechman alternator installed... finally... strokin'_tatsch 1994.5 - 1997 7.3L Power Stroke Diesel 9 08-26-2013 04:31 AM
Murff Racing T4 mounting kit(pics!!) strokin'_tatsch 1994.5 - 1997 7.3L Power Stroke Diesel 56 02-17-2012 02:44 PM
Multifunction switch write up strokin'_tatsch 1987 - 1996 F150 & Larger F-Series Trucks 7 02-12-2011 12:48 PM
Tags
alternator, battery, cable, charge, charger, charging, cord, excursion, f350, ford, gauge, kit, pigtail, size, truck, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
