16" rims om my 65 F100??
If you are referring to me thanks but Im flush now came up with 2 other wheels so have 4 plus a spare. Look for me in projects and you will see the truck with the 16 five lug wheels and P235/85/ 16 tires mounted and rolling.
I have a pair of F100 16" outie rims and a set of four F100 15" outie rims available if anyone needs them. I was using the 16s on my CrewCab to replace the split rims dad put on the truck way back when. I came across the 15s when picking up some rims to use for bases for bike repair stands, so they are not destined for a truck unless someone here speaks up. I have the split rims still stashed away for no apparent reason. I finally found a full set of 5 innie 16s to use with my truck (and original hubcaps) when I get around to fixing things up.
Hello,
Searching on tire sizes and this thread is what I was looking for. I can't quite tell though what the consensus is... I have a '65 F100 fresh out of 33 years of sitting. The 6.50X16's on it hold air for the time being at least. Trying to figure out what tire size is the closest match for the 16 inch stock rims.
Thanks!
Thanks!
chadillac80
01-12-2014 04:57 PM
SoManyFords
05-08-2013 06:20 PM
IDIDieselJohn
08-10-2012 10:18 PM
