Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8 SPONSORED BY:
  #1 (permalink)
Old 01-03-2012, 03:06 PM
jspeedracer88 jspeedracer88 is offline
Garage is empty, add now
jspeedracer88 is starting off with a positive reputation.
Buying new 6.2 truck, need axle ratio opinions for towing!
Buying new crew short bed 6.2 4x4 truck. newbie here. need opinions on my 5ver weight and recommendation for axle ratio and if a 250 is going to squat back of truck more than a 350 will. I live in Indiana where terrain is rolling. We travel thru Kentucky and Tennessee camping 20% and 80% daily driver. what would be best opinion on axle ratio and which truck a 250 or 350. thanks.
Heartland Sundance 5ver,
loaded up empty tanks 11,000 lbs
dry weight 9900 lbs
hitch weight 1910 lbs
GVWR 13,910 lbs.
  #2 (permalink)
Old 01-03-2012, 03:16 PM
kmonty2's Avatar
kmonty2 kmonty2 is offline
2011 Ford F-250
kmonty2 is gaining momentum as a positive member of FTE.kmonty2 is gaining momentum as a positive member of FTE.
kmonty
I would go with the 350, not much more in price, plus it's always better to have more then you need rather then need more then you have. It seems to be a matter of preference on the gearing. From what I have been reading the MPG's are about the same empty. But you should be better towing with the 4.23 gear though. But you could get away with either the 250 or 350, and with either gear. I have the 3.73 gear and have no problems towing at all, but I do have a TT.
__________________
Kevin
2011 F-250 CC, 6.2 Gas, 3.73, 4x4 w/FX4, Tuxedo Black, Steel Cloth interior,Goodyear Wrangler Duratrac's, Air Aid Intake, Bilstein 5100 shocks, Hellwig adjustable sway bar, 5 Star Tuned, Line X bed liner, X Tang Tri-Fold bed cover.
  #3 (permalink)
Old 01-03-2012, 03:24 PM
I'm doing this as my 4 month old F250 2011 6.7 diesel has left me stranded waiting for tow truck the last time. I'm leaning towards the 350 because my 250 squatted a bunch when trailer hooked up. I also plan on doing 18" or 20" tires/wheels from ford on truck so I'm guessing the 4:30 is way to go
  #4 (permalink)
Old 01-03-2012, 03:31 PM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.
Arrow
Yeah...you'll def want to go with the 4.30 gears. The 6.2L is low on torque (IMHO)...and the weight you are towing with the 20" tires...will make it easier with the 4.30.
The 250 or 350 is just preference. A lot of folks get air bags to keep the truck level while towing. My vote is still with the 350.
Good luck with the new SD...and post pics when you get her!
biz
__________________
2012 FORD F250 SD CC 156" Lariat FX4 6.2L BOSS 4x4 4.30s
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s -- Traded
1976 F150 LWB Custom 4x4 390FE NP435 3.50s
  #5 (permalink)
Old 01-03-2012, 08:09 PM
fordmdb's Avatar
fordmdb fordmdb is offline
PREMIUM SPONSOR
fordmdb has a very good reputation on FTE.fordmdb has a very good reputation on FTE.fordmdb has a very good reputation on FTE.
I am a fan of the 4.30 gears and the F350. The 6.2 L will not have any issues pulling your 5ver at 11klbs
Here is our f350 with 5ver its slightly smaller than yours at 10k lbs loaded up.
Its slightly touching the overload spring but 5ver and truck sits pretty level.
Click the image to open in full size.
__________________
Custom Tuning for F-E-Series Engines 6.8L V10 / 5.4L V8 / 4.6L V8 / 6.2L V8 / 5.0L V8 / 3.7L V6 / 3.5L EB and more!
SCT Custom Tuning Dealer
www.5startuning.com email me here:mike@5startuning.com 843-536-1244
  #6 (permalink)
Old 01-03-2012, 09:02 PM
boomsling's Avatar
boomsling boomsling is offline
2011 Ford F-250
boomsling is starting off with a positive reputation.
My camper is 9960 loaded with a 1780 pin weight. My truck sat down about 3 inches in the rear with the camper hooked up. I got Timbrens, now it only sits down an inch.
You might be better off with a 350. I have 3.73 gears and have no problems. 4.30's would probably be better for your application.
__________________
08 Mazda 6i ZoomZoom!
11 F250 Lariat FX4 CC 6.2 3.73
11 Jayco Eagle 30.5 DBSA
Pain is weakness leaving the body.
  #7 (permalink)
Old 01-03-2012, 10:11 PM
Front Runner's Avatar
Front Runner Front Runner is offline
2002 Ford Excursion
Front Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputation
As others have said, F350 with 4.30 gears would be a home run.
__________________
2002 Excursion Limited, 4x4, V10, 4.88 gears, 6" PC lift , 20" XD Hoss wheels, 35" Pro Comp tires
2013 VW GTI 2.0L TSI, 6 speed Manual
  #8 (permalink)
Old 01-03-2012, 10:56 PM
thanks. The dealer let me drive the only 6.2 gas crew cab truck he had home tonight. Its a 250 4x4 with 3.73 gears. I don't really like driving it as the front sits higher than the back end does. It drives almost like a boat! It does have a camper package on it and snow plow package on it so I'm guessing the front springs are much stiffer and that is why the front of truck sits higher? When I get mine, I think all I want is the FX4 package on it. The 350 with 4.30 gear is what I'm leaning towards.
  #9 (permalink)
Old 01-04-2012, 05:46 AM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is online now
2011 Ford F-350
2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all
The 250's seem to come almost level from what I've read, so depending on what packages it has, it'll effect the overall height. The 350's have a larger block in the back so no matter what you get, this truck has a good amount of rake.
Oh yeah, my vote is for the 4.30's as well.
__________________
Matt
2011 F350 - 6.2 CC, LB, 4.30s, Lariat Ultimate pkg, FX4, Amp steps, Lockpick, AC LC6i, JL HD900/5, JL 13TW5, JL C5-570's, Bilstein 7100 stabilizer, Rancho RS9000XL's, Leveled w/ 35" Toyo M/T's and 5 Star tuned
**Sold - 2000 F250 V10, 6.5" Pro Comp, 37" Toyo MT's
  #10 (permalink)
Old 01-04-2012, 06:04 AM
nycsteve nycsteve is offline
nycsteve is starting off with a positive reputation.
The "camper package " option will give you a rear sway bar and beefed up front end foor an extra 140 bucks. The front end with this package sits level, on mine anyway. Good deal at 140 .
  #11 (permalink)
Old 01-04-2012, 11:22 AM
Super08's Avatar
Super08 Super08 is offline
2011 Ford F-350
Super08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to behold
I have it on mine as well. Go 4.30's.
__________________
2012 Ram 3500 Laramie DRW
gone but not forgotten...2011 F350 CC SB Lariat 6.2 4WD 4.30's
  #12 (permalink)
Old 01-05-2012, 04:46 PM
akbash akbash is offline
2012 Ford F-250
akbash is starting off with a positive reputation.
I know I'm out of step with the rest of the world (my wife said so and she's always right!) but if I were only towing 20% of the time I would go with the 3.73 gear, It will give a little better mpg. I have a 2012 250 with the 6.2 and have a place east of Johnson city Tn. I don't tow a camper but my truck dosn't even downshift when I go over Sam's gap on I-26 just before Erwin Tn. Just use tow haul, if you feel the need, thats what its for.
  #13 (permalink)
Old 01-05-2012, 06:22 PM
Super08's Avatar
2011 Ford F-350
Big difference between going up a hill empty and pulling 11 or 12 thousand pounds behind you. That is why I have them. I probably tow 20% or less a year as well but when I do I need that power. You only lose about 1 mpg with the 4.30 gears.
__________________
  #14 (permalink)
Old 01-06-2012, 11:58 AM
biz4two's Avatar
Arrow
Quote:
I agree with nycsteve. With going with the Camper Package. It also adds the rear overload springs...which will help with squat issues.
If you go with the FX4 package...which is overall good...just be aware the Rancho shocks that come with it...are pretty disappointing...to say the least.
biz
__________________
  #15 (permalink)
Old 01-06-2012, 01:07 PM
thanks, I was not aware of that. The more and more I keep hearing about Ford and their customer service with warranty issues, makes me think about looking for a GM Vortec. I hate to say this but.....I think Ford is getting to think their crap just doesn't stink because they survived without gov. assistance.
Tags
430, 62, 62l, aviable, axle, duty, ford, fos, gear, good, ratio, sd, super, towing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
