6.0l turbo diesel cranks no start - Ford Truck Enthusiasts Forums
Old 01-03-2012, 02:46 PM
Noey_Gonz Noey_Gonz is offline
Noey_Gonz is starting off with a positive reputation.
Exclamation 6.0l turbo diesel cranks no start
i have 2005 f-450 6.0l turbo diesel that came in for low power and running rough..... so i had my technician diagnose it and what he came up with was it was not going through the buzz test for the injectors, so we had a ficm replaced and flashed, and got it running, next day customer drives to the gas station and turns off vehicle after fueling vehicle cranks and no start, we tried to diagnose it again and we ended up putting another ficm and flashing but still no crank no start then we put on hpop and still nothing, then we sent it to ford and have them to diagnose and they came back with the ipr voltage reading was low, so they suggested changing it out so we did, replaced and it took awhile to start but finally did, a week later customer brings truck back to change out tire we return it and and vehicle dies on us and cranks but wont start..... so we bring it back and try to diagnose but no luck, we send it back to the dealer and they tell us that there is alot of trash build in the ipr and looks beatup, so we change it out along with egr cooler the screen and cleaned it out, put it back together and still cranks but no start, did some reseaqrch online and saw some ploblems with the dummy plug o-rings, so we changed tose out aswell due to the orings had tears and pieces missing but still cranks no start..... so at this point i have no clue, and to see if anyone has any advice on what to check next??? would gladly appreciate it
Old 01-03-2012, 03:00 PM
9228.bobcat's Avatar
9228.bobcat 9228.bobcat is offline
9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.
Maybe ficm wiring harness. Hard to tell. Alot of work has been done without diagnosing the problem. Any codes?? How about the fuel pressure?
Old 01-03-2012, 03:23 PM
Yeah... but no codes and I have not check fuel pressure, but we did try to start it with starter fluid and still nothing
Old 01-03-2012, 05:45 PM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
PLEASE don't use any starting fluid. That's an easy to break pistons and rings.
Air test the HPO system and look/listen for a leak. Also, what is your ICP voltage and IPR% cranking. Give us something other than repair descriptions please. Numbers help a LOT. Regarding the HPOP---just because you replaced it doesn't necessarily mean it's good. I've seen more than one "new" HPOP be bad.
Old 01-03-2012, 05:54 PM
fixxxer-upper's Avatar
fixxxer-upper fixxxer-upper is offline
FTE Fan
fixxxer-upper has a good reputation on FTE.fixxxer-upper has a good reputation on FTE.fixxxer-upper has a good reputation on FTE.
What are you using to read the codes? My experience has been that the generic scanners will only scan the OBDII faults the pertain to the emissions. You need something that can scan the ford enhanced codes. When scanning my truck, no codes were reported using generic scanners. Auto Enginuity reported 8 that the others didn't "see".
Old 01-03-2012, 06:12 PM
wulfman wulfman is offline
wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.
Not trying to be a smart **** but why don't you let the dealer fix it, they have the tools and know how to do it . Also if the dealer told you the IPR had trash in it the second time they had it then they had to have it out to see it , so then they put it back and told you about it .
Please help with my 2003 f350 6.0 Diesel! Colton Haight 1999 to 2016 Super Duty 13 10-02-2016 01:18 PM
Frustrating uncommon 6.0 no start issue nandos_camaro 6.0L Power Stroke Diesel 14 03-06-2016 09:09 AM
2004 early 6.0 no start dothedew192 6.0L Power Stroke Diesel 10 02-21-2016 10:58 AM
2004 F-250 6.0 bostonsean 6.0L Power Stroke Diesel 104 12-24-2014 07:38 PM
6.0L No Start Mystery dpassarella 6.0L Power Stroke Diesel 17 03-30-2014 08:55 PM
Tags
05, 60, 60l, bad, cooler, crank, cranks, deisel, diesel, egr, f250, ford, pressure, start, tsb, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
