Does a clutch master needs a residual valve
I am installing dual master cylinder below the floor. There is lots written about needing a 2 psi residual valve for disc brakes and 10 psi for drums. My question is does the clutch master need a residual valve. The application is actually a car, but should be the same as our old trucks.
Received 1,346 Likes
on
It really doesn't matter what the relationship between the slave and master is for a clutch. As soon as the pressure plate isn't pushing back on the slave, there is nothing to cause fluid to go back into the master. Rusty has it right, you don't want the release bearing riding the PP when the clutch is released.
Claybreaker144
01-25-2017 09:31 PM
maxride
08-28-2015 05:54 PM
willow72
12-03-2006 01:48 PM
JustinGustafson
11-16-2006 01:42 PM
cbfomoco
01-28-2006 07:02 AM
