front shock/strut replacement - Ford Truck Enthusiasts Forums
Old 11-21-2014, 01:52 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
Print Wikipost
Old 01-02-2012, 03:36 PM
Brian429 Brian429 is offline
Brian429 is starting off with a positive reputation.
First off pardon me for any stupid questions I might ask here.
I am long overdue for new shocks on my '06. The struts on the front can be replaced just by themselves, correct? Everywhere I call for some reason is giving me a price on the whole strut assembly, assuming thats with the spring?
I have a 3" leveling kit on my front, should that require different struts then a stock front end? Most places are telling me no, but I think I read on here where some guys got different struts? I guess I've been driving around with the factory struts with the leveling kit so I should be ok to just replace them?
Old 01-02-2012, 04:14 PM
keisha9 keisha9 is offline
keisha9 is starting off with a positive reputation.
dude get some shocks and reuse your springs, if you have the leveling spacers that is. If you have a lift get longer shocks. bilsteins are good for trucks. i personally run the 5100. the guy that tried to sell u a whole strut assembly wants your money. have a good day
Old 01-03-2012, 01:34 PM
aquaman aquaman is offline
aquaman is gaining momentum as a positive member of FTE.aquaman is gaining momentum as a positive member of FTE.
Agreed. No reason to swap out the whole assembly
Anyone here do their shocks themselves? How much of a hassle is it? I replaced my own shocks on my cars in the past by removing the whole strut. Kind of a pain, but it was manageable. How does this compare?
How do the 5100's ride compared to factory Ranchos?
Old 01-03-2012, 03:58 PM
Coskid's Avatar
Coskid Coskid is offline
Coskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to behold
The work is not overly hard to replace the front shocks but there is a danger in that the spring has a lot of pressure on it and unless you have the knowledge to make sure that spring is not going to come loose while removing the shock I would not do it. You can do this either with the piece of equipment designed to keep the tension on the spring while you take the rest of the assembly apart or I have even see people do it using nylon tension straps to hold the spring in place and then release it once the new shock is installed and the assembly put back together. Again there is a danger in doing it so you take responsible for yourself.
Old 01-04-2012, 04:51 AM
04fxdwgi 04fxdwgi is offline
04fxdwgi is gaining momentum as a positive member of FTE.
Quote:
Rent the strut spring tool at one of the auto supply houses. It's an easy job with the tool. I wouldn't do it without the proper equipment, as I have seen one come apart when a fellow was trying to do it on the cheap without the tool and he almost took his head off when the spring came loose. He needed 8 stiches on the side of his head to close it up. He was lucky......
Bottom line, be safe and take it slow. It's a really easy job to do and be safe too.
Can Navigator air struts be rebuilt?? AGrayson84 1997-2006 Expedition & Navigator 5 10-25-2016 01:14 PM
Changing JUST shocks (but not springs) on a 2007+ (3rd Gen) Expedition sfc2001 2007 - 2014 Expedition & Navigator 18 09-19-2016 08:59 AM
New 2.5" Leveling Struts by Rough Country Beer.Tom.F150XLT 2009 - 2014 F150 7 07-23-2016 08:24 AM
04 Explorer w/ stuck lower strut bolt UGA33 Explorer, Sport Trac, Mountaineer & Aviator 3 06-06-2014 06:57 PM
Bilstiens vs Sensatrac 442w30 Brakes, Steering, Suspension, Tires, & Wheels 2 12-05-2009 09:46 PM
Tags
150, 2003, 2004, 2006, expedition, f150, ford, forum, replace, replacement, shock, shocks, strut, struts, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
