Overcharging? reading 15.5v
My dads truck shutoff while driving the other day after the battery light came on. He restarted and hasn't had any running issues since.
I plugged in the SGII and the main ficm power was right at 48, his other ficm voltages were at 15. I then checked the voltage and it read 15.5. We popped the hood and alternator said it was putting out 15.5 volts. We then check both batteries and they checked out low so we replaced them. The battery light is still on and will go in and out intermittently.
Any thoughts?
Any thoughts?
Any thoughts?
Any thoughts?
You should also clean Both the main engine grounds that may help.
But if you clean the grounds and it still putting out 15+ volts I wouldnt run it anymore be a shame to waist them new batterys
Check into a DC Power alternator they are good units if you can spend that kinda cash on it. The chain part stores are hit and miss on Good units
https://www.dcpowerinc.com/
Etzcutter
01-25-2015 08:40 PM
