Tranny code
Old 01-03-2012, 12:50 AM
brain75's Avatar
brain75
brain75 is offline
I wasn't about to volunteer that I am doing a ton of research given that the experts I rely on (havi, mtflat, albuq, 4tl8ford, etc) all beat me to the punch answering this thread first.
I am by no means an expert, but I have started to write down what little I have learned. There are some real definite easy and common swaps I think in the F2+ series... which brings me to this answer:
since you identify as a F1 in the 2nd post.... WITHOUT cutting the stock crossmember there is no T98 that will work - they were big truck only, they work with the larger crossmember, not a T98, not a T98A, not a T18, not a T19 (all the same family) will fit a F1 with stock crossmember. If you are willing to fab or buy a 3rd party crossmember and shorten driveshaft then all those should fit and we have examples of members who did the T98, and T19 (no T98A or T18 that I know of).
Dick from Penn is one of the sharper cookies, he's got humor though and I think that is all his post was. He has done some trans swaps I believe (he's got a ton of posts about it) - like I said he's one of the smarties I rely on.
If you want to see what that T98 family looks like in a F1 behind a flathead, then HD74 has done a T19 behind a french flathead - he had to cut the stock crossmember.
Old 01-03-2012, 10:03 AM
GreatNorthWoods's Avatar
GreatNorthWoods
GreatNorthWoods is offline
Originally Posted by 4tl8ford
Maybe someone with a magic decoder ring will show up
Well Dick, at least he called you by name!
That decoder ring may be necessary 'cause I'm pretty sure Dick is done.
What's the big deal about using using a transmission that's been in a Jeep? It's my understanding the T-98 was used in a number of different makes...
Old 01-03-2012, 11:37 AM
CPR51FRD's Avatar
CPR51FRD
CPR51FRD is offline
It was used in alot of things it is just a personal preference. Talked a little more to the guy i got tranny from he got it out of an F-6 a customer dumped on him that he parted out a couple years ago.
Old 01-03-2012, 04:23 PM
GreatNorthWoods
Sooo, it doesn't matter where it was BEFORE it was in the F6?
Old 01-03-2012, 05:00 PM
CPR51FRD's Avatar
CPR51FRD
CPR51FRD is offline
I guess not I had no idea I thought he had left town
Weasel's_Truck
09-18-2004 10:17 AM
dcrewchief
07-25-2004 04:06 AM
parks911
1978 - 1996 Big Bronco
04-30-2004 12:12 AM
Quick Reply: Tranny code
