Whats new!
Old 01-02-2012, 09:03 AM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
Whats new!
Hi guys! I've been working on a bunch of new bio projects since we moved into the new house/shop, and thought I'd update everyone.
I've been working on a new way to remove the glycerol MUCH faster than settling overnight. I've found I can remove the glycerol in just a few minutes with high voltage/low amperage DC in my lab. I'm now working on a way to do it in a continuous basis rather than just in batches.
The other system I'm working on is Ultrasonic Transesterification. I got the idea from a good friend that owns a commercial biodiesel plant and has been looking at a commercial design from here: Ultrasonic Processors for Biodiesel Production
It does work in a "batch" system in the lab, and I've ordered the parts to build a continious system for home brewers. It may take me a month or two to get any concrete results, but I will keep everyone informed on my progress!
Stay tuned for updates...........
Old 01-04-2012, 09:43 AM
Rushmore X's Avatar
Rushmore X
Rushmore X is offline
Looks good, glad to see you're still hard at work.
Old 01-09-2012, 06:55 PM
Tom D's Avatar
Tom D
Tom D is offline
Nice work Don
I'm ready to build a better processor. I will wait for more reports from you.
Tom
Old 01-09-2012, 07:05 PM
fabmandelux
Wow! There are still people in this forum..................lol
Thanks guys. I've got a real good feeling on this process. I't could make the process much quicker, and SAFER!
So far I've found 20,000 cycles at about 100 watts works ok with about half of my normal Methoxide mix at about 100 deg. Complete mix and great bio! It was only a 1 gallon batch though. Next is to build a little higher wattage unit (500-1,000 watts) and try it in a tube from one container to another rather than in a batch. If I can get this to work RELIABLY it could change the way we "homebrewers" do things........
Old 01-10-2012, 12:24 AM
luv_mud's Avatar
luv_mud
luv_mud is offline
If anyone can do it I'm sure it will be you. Thanks for the updates and for all the info you share.
Old 02-20-2012, 07:03 PM
444dieselrod's Avatar
444dieselrod
444dieselrod is offline
Subcribing, wanna see how this goes!
Diesel Rod
Old 02-25-2012, 07:45 PM
Marianna2003's Avatar
Marianna2003
Marianna2003 is offline
Hey fabmandelux, Very interesting. Have you seen the novelty dishes that create fog from water with an untrasonic transducer? Do you think that putting one of these transducers in a tee in a line and flowing the mixture accross the transducer would effect the same result as the article talks about?
Old 02-25-2012, 08:27 PM
fabmandelux
I don't have one to try, but the transducer I do have does work on a small scale. Just waiting on a bigger model I ordered to try on a continious trial.
Old 02-26-2012, 04:11 PM
Marianna2003
I think the ultrasonic vaporizers use the same or similar transducer.
Old 02-29-2012, 11:07 PM
97biostroke's Avatar
97biostroke
97biostroke is offline
How did you end up building your electrostatic separator? I'm in an advanced electronics circuits class right now and would like to tinker with one. From what I've seen they've always been made to fit in a small diameter tube, wondering if anyone built one that can be used in large tanks.
Old 03-01-2012, 11:34 PM
ATV PRO #11's Avatar
ATV PRO #11
ATV PRO #11 is offline
PM me if you have questions regarding troubleshooting the UP's. We used 3 of them in our process at 3.25gpm. Pressure and temperature is SUPER sensitive with these. Also make sure to get the amplifiers, spare O-Rings. If you start these babies without fluid in them it causes lots of damage to the head. Very expensive to replace and just getting a machine shop to fab some titanium heads up for these units just doesn't work. Hielscher would not comment on the propriotary info on how these metals are "Tuned" for the process but did confirm, and we did as well by testing some homemade one's, they are tuned.
Can you mention who you have that is using these? I was under the impression that the plant I formerly worked at/commisioned were the only ones around to have and use these.
Old 04-11-2012, 07:08 PM
Tom D's Avatar
Tom D
Tom D is offline
Hey Don
Hope all is well with you. How is new process working out? I'm still plugging along making 50 gallons at a time. I'm surprised there isn''t more activity on this forum considering the price of diesel.
Keep in touch
Tom
Old 04-11-2012, 07:24 PM
fabmandelux
Evening Tom! Still plugging along here. I've completed some work on the new process, but mostly been working on the new house and new shop. I thought when I retired 2 years ago that I'd have more time, but I'm now busy 8 days a week............Maybe I should go back to work so I could have more time to work on projects?
I still haven't been able to figure out why this forum is so dormant. Last time the price of dinodiesel was this high, this forum was smokin..........
Old 04-12-2012, 09:31 AM
Rushmore X's Avatar
Rushmore X
I'm going through withdrawl. My sources of oil went out of business and haven't been able to secure new ones yet (although tourist season is starting soon). Hopefully I get back into the groove soon, would be nice to pay a third as much for fuel again...
Old 04-12-2012, 09:35 AM
fabmandelux
I get more oil than I need now that I don't have a farm to run. I've got over 4,000 gallons of WVO in tanks just waiting for summer.........
Quick Reply: Whats new!
