Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 01-02-2012, 09:03 AM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Whats new!
Hi guys! I've been working on a bunch of new bio projects since we moved into the new house/shop, and thought I'd update everyone.
I've been working on a new way to remove the glycerol MUCH faster than settling overnight. I've found I can remove the glycerol in just a few minutes with high voltage/low amperage DC in my lab. I'm now working on a way to do it in a continuous basis rather than just in batches.
The other system I'm working on is Ultrasonic Transesterification. I got the idea from a good friend that owns a commercial biodiesel plant and has been looking at a commercial design from here: Ultrasonic Processors for Biodiesel Production
It does work in a "batch" system in the lab, and I've ordered the parts to build a continious system for home brewers. It may take me a month or two to get any concrete results, but I will keep everyone informed on my progress!
Stay tuned for updates...........
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #2 (permalink)
Old 01-04-2012, 09:43 AM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
Looks good, glad to see you're still hard at work.
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #3 (permalink)
Old 01-09-2012, 06:55 PM
Tom D Tom D is offline
Garage is empty, add now
Tom D is starting off with a positive reputation.
Nice work Don
I'm ready to build a better processor. I will wait for more reports from you.
Tom
__________________
93 F-250 7.3 Banks turbo, 3.5" exhaust 4" ram air K&N filter E40D 4.10. Pyro, boost, & tranny temp gauges. Tru Cool 28,000 GVW trans cooler. 100% BIO
  #4 (permalink)
Old 01-09-2012, 07:05 PM
1935 Ford pickup
Wow! There are still people in this forum..................lol
Thanks guys. I've got a real good feeling on this process. I't could make the process much quicker, and SAFER!
So far I've found 20,000 cycles at about 100 watts works ok with about half of my normal Methoxide mix at about 100 deg. Complete mix and great bio! It was only a 1 gallon batch though. Next is to build a little higher wattage unit (500-1,000 watts) and try it in a tube from one container to another rather than in a batch. If I can get this to work RELIABLY it could change the way we "homebrewers" do things........
__________________
  #5 (permalink)
Old 01-10-2012, 12:24 AM
luv_mud luv_mud is offline
luv_mud is gaining momentum as a positive member of FTE.luv_mud is gaining momentum as a positive member of FTE.
If anyone can do it I'm sure it will be you. Thanks for the updates and for all the info you share.
__________________
Gord
"Enemy of the Government of Canada"
Civil disobedience. A right, not a crime.
  #6 (permalink)
Old 02-20-2012, 07:03 PM
444dieselrod's Avatar
444dieselrod 444dieselrod is offline
1996 Ford F-250
My Garage
444dieselrod is gaining momentum as a positive member of FTE.
Subcribing, wanna see how this goes!
Diesel Rod
__________________
'96 F250, Reg Cab 7.3 PSD, Auto, 4x4, XLT.
'97 F250, Ext Cab 7.3 PSD, Auto, 4x4, XLT.
'96 F250, Crew Cab 7.3 PSD, 5-SPD, 4x4, XLT.
'99 Jetta TDI, 5-SPD
'87 359 Peterbilt SHORT HOOD, 36" sleeper. 13 speed, 425 intercooled Cat.
  #7 (permalink)
Old 02-25-2012, 07:45 PM
Marianna2003 Marianna2003 is offline
1992 Ford F-350
My Garage
Marianna2003 is gaining momentum as a positive member of FTE.
Hey fabmandelux, Very interesting. Have you seen the novelty dishes that create fog from water with an untrasonic transducer? Do you think that putting one of these transducers in a tee in a line and flowing the mixture accross the transducer would effect the same result as the article talks about?
__________________
  #8 (permalink)
Old 02-25-2012, 08:27 PM
1935 Ford pickup
I don't have one to try, but the transducer I do have does work on a small scale. Just waiting on a bigger model I ordered to try on a continious trial.
__________________
  #9 (permalink)
Old 02-26-2012, 04:11 PM
1992 Ford F-350
My Garage
I think the ultrasonic vaporizers use the same or similar transducer.
__________________
  #10 (permalink)
Old 02-29-2012, 11:07 PM
97biostroke's Avatar
97biostroke 97biostroke is offline
97biostroke is starting off with a positive reputation.
How did you end up building your electrostatic separator? I'm in an advanced electronics circuits class right now and would like to tinker with one. From what I've seen they've always been made to fit in a small diameter tube, wondering if anyone built one that can be used in large tanks.
__________________
1997 F-250 PSD
6" Skyjacker
315 Mickey Thompson MTZ
16x10 Eagle Alloy 186's
  #11 (permalink)
Old 03-01-2012, 11:34 PM
ATV PRO #11's Avatar
ATV PRO #11 ATV PRO #11 is offline
ATV PRO #11 is gaining momentum as a positive member of FTE.
ATV.PRO.RACER.11
PM me if you have questions regarding troubleshooting the UP's. We used 3 of them in our process at 3.25gpm. Pressure and temperature is SUPER sensitive with these. Also make sure to get the amplifiers, spare O-Rings. If you start these babies without fluid in them it causes lots of damage to the head. Very expensive to replace and just getting a machine shop to fab some titanium heads up for these units just doesn't work. Hielscher would not comment on the propriotary info on how these metals are "Tuned" for the process but did confirm, and we did as well by testing some homemade one's, they are tuned.
Can you mention who you have that is using these? I was under the impression that the plant I formerly worked at/commisioned were the only ones around to have and use these.
  #12 (permalink)
Old 04-11-2012, 07:08 PM
Hey Don
Hope all is well with you. How is new process working out? I'm still plugging along making 50 gallons at a time. I'm surprised there isn''t more activity on this forum considering the price of diesel.
Keep in touch
Tom
__________________
  #13 (permalink)
Old 04-11-2012, 07:24 PM
1935 Ford pickup
Evening Tom! Still plugging along here. I've completed some work on the new process, but mostly been working on the new house and new shop. I thought when I retired 2 years ago that I'd have more time, but I'm now busy 8 days a week............Maybe I should go back to work so I could have more time to work on projects?
I still haven't been able to figure out why this forum is so dormant. Last time the price of dinodiesel was this high, this forum was smokin..........
__________________
  #14 (permalink)
Old 04-12-2012, 09:31 AM
Rushmore X's Avatar
2003 Ford Excursion
I'm going through withdrawl. My sources of oil went out of business and haven't been able to secure new ones yet (although tourist season is starting soon). Hopefully I get back into the groove soon, would be nice to pay a third as much for fuel again...
__________________
  #15 (permalink)
Old 04-12-2012, 09:35 AM
1935 Ford pickup
I get more oil than I need now that I don't have a farm to run. I've got over 4,000 gallons of WVO in tanks just waiting for summer.........
__________________
Tags
28000, 60, cool, cooler, lb, powerstroke, tru
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
