Will not start
#91
Then opening up the jug and carefully pouring in high-Molarity Sulfuric acid into each of the cells?
Then heft the battery back up and over the fender?
At a minimum, you should be wearing safety goggles (not glasses), and have plenty of water ready right by you in case of accident.
After all that, if the battery was sulphated up, or swelled plates, or high resistance intercell connector, or any number of other things, replacing the acid in it will not do any good.
If you can't wait to save up for a new battery, maybe some place that works on cars would sell you a used battery, real cheap. Just have to make sure that it fits your tray and hold-down. And that the cables can reach the proper posts.
The more urban an area you live in, the more likely you will be able to find a place that sells pullouts. It's like buying used tires. They should be able to look up to see what batteries would fit a Bronco.
#92
Jim, you might want to think that through first. Is it a good idea for a partially-disabled person to be lifting the battery up and out of a Bronco, dumping it upside-down somewhere safe to empty it, standing it back up, and neutralizing all of the spilled acid off of the outside of the case, without getting any on you or, disaster, in your eye?
#93
On the Road again!
I was not totally happy with the acid trick as I figured it might not even work and I would have gone through the hassle for nothing.
So, Joe (JoeF350), who only lives 10 miles south of me now, came up and we went to the local Pick-n-Pull and I bought a reconditioned battery for $26.99 ($31.55 with tax and environmental fee) that even comes with a 6 month warranty. Joe carried the old one in and the new one out. He popped it in the truck, and presto-chango, it started right up! I am now a happy camper again!
Thanks Joe for all your help.
Jim
PS: I had already opened up the covers, and topped off the water in the battery. if I did buy the acid, I would have done what was mentioned above, however, now that I think about it, I don't think it would have been possible for me to do that. Getting it out of the Bronco alone would have been hard enough, tipping it over, and hoping I don't get splashed with acid would have been next to impossible.
Jim
#94
Ya it sounds like buying the recon one was a lot easier. Glad its back up and going. You know i had a brain fart a few days ago, went out to warm my truck up and no start... I though "Oh great whats broken now" I tried my lights and they all worked, went out and made sure i had no loose connections all that crap. I had though my started was frozen or something so i grabbed my hammer and was going to get my creeper so i could pound it and try again. But i decided to try jumping to solenoid to see what would happen and BAM it cranked... The whole truck lurked which kind of worried me but i was more worried about getting it running so after i got it started i went back into the house. and when i went out to leave i said to myself " You know i wonder if it was in park" and turns out it was ever so slightly in reverse hence the lurching and low idle and not starting... I felt like a dumba§§ for most of the morning. I have had to replace almost every part of the starting system so i thought the solenoid went out..
#95
#97
banner1124
05-21-2006 06:26 PM
