PLease HELP - F-150 won't go above 30 mph - Ford Truck Enthusiasts Forums
Old 01-01-2012, 06:41 PM
Deborrah Deborrah is offline
Deborrah is starting off with a positive reputation.
Question PLease HELP - F-150 won't go above 30 mph
Hello - My truck will not go above 30 mph - rpm's will rev high but, speed will not climb. I was able to put the truck in 2nd gear and drive home at @ 40 mph. Truck has 135K miles on it, I'm the original owner. If anyone has any ideas as to what this might be I would greatly appreciate any info before going the mechanic.
Old 01-01-2012, 07:06 PM
Shooter00's Avatar
Shooter00 Shooter00 is offline
Shooter00 is starting off with a positive reputation.
Sounds like transmission. I'd start with having it flushed, unless the fluid smells burnt. If the fluid on your dip stick smells and it is dark, you may have smoked it.
Is your check engine light on? May run the codes see if it is something else.
Old 01-01-2012, 07:10 PM
Thanks for the reply ... no engine light ever came on ... didn't smell anything burning ... ugh, I can't afford a new transmission
Old 01-01-2012, 09:01 PM
Coskid's Avatar
Coskid Coskid is offline
Coskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to behold
Just start with checking out the fluids and then doing a flush and make sure who ever does it inspects the bottom of the pan well. Best of luck too you.
Old 01-01-2012, 09:45 PM
jt351 jt351 is offline
jt351 is starting off with a positive reputation.
Don't waste time on a flush, A flush will never ever ever fixes anything. if it is the transmission flushing it will just waste money, take it to a trans shop to just let them drive it. also give a little more specifics, year, engine, etc. so will it not shift, does it shift from 1 to 2 when manually shifted?
Old 01-02-2012, 08:46 AM
Coskid's Avatar
Well no a flush will not fix it but getting the fluid out and looking at it and cleaning out the insides will at less give some more insight on the issue at hand. And the more information you can take to a shop the better off you usually are unless you trust the shop completely.
Old 01-02-2012, 11:54 AM
Thanks for the reply ... don't know how often you check back in ... but, yes the truck will manually shift from "D" to 2nd gear. It's a 2005 F-150, 5.4 EFI V8 engine ... any ideas would be great.
Old 01-03-2012, 07:53 PM
hydro_37 hydro_37 is offline
hydro_37 is starting off with a positive reputation.
just stop by a transmission shop. I sure wouldn't waste money on a tranny flush.
Old 01-06-2012, 01:01 AM
Shooter00's Avatar
I'll disagree with jt351...I've had several higher mileage vehicles come through the shop that would shudder and lag that a flush completely solved the problem. Flushing out old crud than can be clogging the ports and inlets for $80 is a lot better than the cost to drop a tranny and rebuild. It's a good first shot for cheap, always start with the easiest and least expensive fix first! A shop is going to charge at least an hour labor to start to diagnose an issue like this, at a minimum of $75 an hour.
Old 01-10-2012, 01:58 AM
Quote:
Well you are correct shudder and lag is a cause of fluid deterioration, but no shift at all is electrical or just plain screwed. And a slightly slipping trans with black fluid usually will totally fail with a flush cause new fluid is thinner. But go ahead and change fluid and throw more money away. It could be just a MLP switch or TP sensor. Most shops including Aamco will at least test drive it at no cost.
Old 01-11-2012, 10:54 AM
NCFireMedic315 NCFireMedic315 is offline
NCFireMedic315 is starting off with a positive reputation.
If as you were driving your rpm's just kept rising but you were not going any faster, it sounds like a snap ring for your drive or over-drive gear. This would not allow for your transmission to shift into the next gear properly. Which in turn would not let you exceed the speed set for the transmission to shift. This is about a 1300-1600$ fix. Don't waste you time or money on a flush, but you could save a couple bucks and buy the gasket, fluid, and filter on your own instead of the shop charging you 21% over the sale price of these parts.
Old 07-08-2014, 11:49 AM
Isaiah Miranda Isaiah Miranda is offline
Isaiah Miranda is starting off with a positive reputation.
Cool 2006 Ford Expedition Ran out of gas
Hi
The other day my wife was driving the car and it ran out of gas. So I walked over to where she was at a filled a little less then a gal of gas in the tank and luckily we were in the neighborhood so i drove it home slowly. I went to get 6 more gals of gas, and it is running like crap. It has a rough idle and won't drive over 20mph. I've changed sparkplugs, fuel filter and both camshaft sensors. I have a codes now for camshaft P0345 P0349 and running lean and rich codes P2197 and P2198. I'm stuck and have no idea what to do. Any help would be appreciated.
Old 07-08-2014, 01:11 PM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
Aside from possible clogged injectors, a fried/overheated fuel pump comes to my mind.
Old 07-08-2014, 01:48 PM
ojai150 ojai150 is offline
ojai150 is starting off with a positive reputation.
Running any modern vehicle , with the pump in the tank , is bad news.
the pump is designed to be immersed in gas , when you run one out of gas ,
the armature in the pump is exposed , and gets very hot very quick , and can fry the pump , and/or the wiring attached to it .
might also check fuse .
Old 07-08-2014, 06:00 PM
1saxman's Avatar
1saxman 1saxman is offline
1saxman is gaining momentum as a positive member of FTE.1saxman is gaining momentum as a positive member of FTE.
I don't let any of my FI vehicles get under 1/4 tank for that reason.
interchangeable doors? tammyup60 1997 - 2003 F150 2 02-15-2016 04:25 PM
Service Interval on new 6R140 in heavy 550's ?? L&D's Broncos 1999 to 2016 Super Duty 5 07-19-2012 04:09 PM
6.4L with turbo problems 08F250SD_Laredo 1999 to 2016 Super Duty 5 03-02-2010 02:35 PM
Leather in Platinum vs. Lariat Marauder89 2009 - 2014 F150 3 01-20-2010 11:54 AM
A/C clutch not kicking on cmorningstar01 1997 - 2003 F150 13 07-21-2009 06:12 AM
Tags
30, 30mph, accelerate, econoline, ford, high, hour, miles, mph, pass, rpm, runs, truck, vehicle, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
