Some more oil leak question for a newbie
I have had my 2001 F250 for four months now and have learned a lot from this forum so far. Had to put a starter on last weekend and noticed a oil leak coming down off the rear of the passenger head/valve cover area. Looked on top an the valley seems wetter towards the rear. Passenger side intake looks very wet and caked with oil, intake boots from spider caked with oil and a hard line running around the back of the passenger valve cover area looks wet with oil. All these seem to have been seeping a while .... Not fresh oil. Looked under the turbo and it seems to be dry. Also noticed the IPR is wet but the hoop lines seem to be ok as we'll as underneath the hpop. curios what would cause the oil to cake on to of the intake.
That would be the fuel line for that head. From where you see the drip, if it's fuel it would most likely be from the seals on that line. If it is oil look at the EBPV rod where it comes out of the turbo pedestal.
What Jim said.
There is a clamp on the passenger side fuel line about half way back near the spider. That clamp can wear a hole in the line. A leak there will usually run down the back of the engine and drip from the bell housing.
If it is a seal on that line, take the line completely out. Replace the seals on both ends and put some thin rubber hose (vaccuum line) on the line where the clamp is. That will prevent the clamp from rubbing a hole in the line. Then reinstall. You can manuver the line out without removing anything else. Disconnecting the passenger side intercooler pipe helps make room to get to the back fitting. Ford has a seal kit for about $25. Be sure to follow the instructions included in the kit for tightening the fittings.
logcruiser
03-09-2014 06:53 PM
kickerman248
01-11-2010 08:12 PM
