Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
  #1 (permalink)
Old 01-01-2012, 11:29 AM
pkm pkm is offline
1999 Ford f-250 Super Duty
pkm is starting off with a positive reputation.
Unhappy airbag light stays on 99 f250 sd
i have a 99 f250 sd my airbag light on dash is staying on. the passinger one not lighting up. my heat blower is not working ethier. all fuses good under hood and dash. happened right after 30amp in dash went out
  #2 (permalink)
Old 01-01-2012, 11:54 AM
Fulltimer50's Avatar
Fulltimer50 Fulltimer50 is offline
Garage is empty, add now
Fulltimer50 is starting off with a positive reputation.
Normally with no other problems it means the passager lite is out. I took the unit out and replaced the bulb with a dash bulb. You seem to have more than one problem.
__________________
George
6/2011 F350 6.7PSD 4X4 CC LB DRW Lariate
2013 Lifestyle LS37RESL 5th Wheel
  #3 (permalink)
Old 01-01-2012, 06:48 PM
1973Ford2004 1973Ford2004 is offline
1973Ford2004 is gaining momentum as a positive member of FTE.
Quote:
I second this advice, sounds like a short, start chasing wires on that circuit
  #4 (permalink)
Old 01-01-2012, 08:57 PM
pkm pkm is offline
Air Bag Module, Passenger Air Bag
Activation/Deactivation Switch, Blower
Motor Relay Coil
all on #22 fuse but not blow went out same time
Tags
07, 2000, 2001, 2008, 250, 99, air, airbag, bag, deactivation, escape, f250, ford, light, passenger, stays, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
