Pics or it didn't happen!
Received 3,102 Likes
on
my permits were for 14 foot, 82 foot long, and 276,000 lbs. the blade on the D11 dozer was 13 foot 11 3/4 inches wide. the 365 excavator was 11 ft 6 inches wide.
the D-11 weighed around 226,000 lbs, the 365 excavator was rite around 146,000 lbs.
i used to have to take the 22 foot wide blade off the dozer if we were going to be using it and put it on another trailer to move it.
Next time you are in a passenger car, at a stoplight next to a 18-wheeler, note that your eye level is at, or only slightly above the lug pattern on their wheels...........then think about it.
I have no idea what they weighed, but it's as much as I've ever seen put on a truck. The railroad yard was a few blocks from the boiler company making it was necessary to move the boiler by truck to the railroad yard. It took 4 tries to get the first one there due to the extreme weight.
The boiler was loaded on a low-boy and secured. When the truck left the yard, the trailer got hung up on the crown as it tried to get onto the road.
Attempt number 2 met immediate failure as the weight of the boiler was too much for the trailer. The low-boy's yoke broke under the strain.
Attempt number 3 had partial success. The truck and trailer got onto the road. At the one-block mark, a 90-degree left turn was required. Even though the load was secure, all of the trailer tires on the right side blew when the rig attempted the left turn.
The boiler finally arrived at the railroad yard on the 4th run.
With the lessons learned from moving that boiler, they did manage to get the second one there in one pass.
It is simple, the car did not have enough safe room to move over and shouldn't have. She should have had at LEAST 6 spaces between her and the semi she was passing ON THE RIGHT mind you before moving over into his lane.
Sure the semi driver saw it, knew what was going to happen, but it is not his job to avoid the idiot. He shouldn't have to make adjustment to his driving to accommodate the idiot. Yes he could have put his brakes on and let her in but he shouldn't have to, she should have saw she didn't have enough gap to move over and she was the one that should have braked.
All the cars fault.
All the cars fault.
The passing on the right issue we do not have enough information to judge. Of question is where the VW was in relation to the truck when it became clear to the VW that it must move left to continue past the truck in the right lane. It's also important to note that the truck was likley not keeping right. If it's possible to be passed on the right then you are not keeping right.
In an ideal world I tend to agree, trucks own the highways, simple fact. We pay the vast majority of the highway taxes and the highways system was created with trucking in mind. To my mind trucks should always have the right of way. But that's not the real world as it is today. Today the meek have power the strong by the virtue of their weakness.
Received 5,155 Likes
on
Received 3,988 Likes
on
Received 4,132 Likes
on
on
