Power Steering Conversion - Ford Truck Enthusiasts Forums
Old 01-01-2012, 08:17 AM
racer2012 racer2012 is offline
racer2012 is starting off with a positive reputation.
I want to convert my 65 F-100 to power steering .. I need a shorter automatic column .. Hope to get some ideas on how others have done this and if theres any aftermarket options that have been tried ...
Old 01-01-2012, 12:33 PM
oldblu oldblu is offline
oldblu is starting off with a positive reputation.
I am in the middle of this process myself. I took the power steering and steering column from a 1978. As I understand it, any 1973-1978 will do the trick. I had hoped to keep the steering wheel from my 66, but I don't see a clean way to make it work.
Old 01-01-2012, 02:01 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
As I understand it, any 1973-1979 will do the trick.**
Same 3 spoke steering wheel: 1960/63 Falcon/Comet / 1961/66 F100/250 2WD / 1966 F100 4WD / 1966/73 Bronco / 1967/70 F100/250 2WD/4WD / 1969/70 F350.
Ford/Saginaw integral P/S: 1969 F100/250 2WD & F350 from serial # D96,001 / 1970/79 F100/350 2WD / 1975/79 F150 2WD / 1976/79 F100/150 4WD / 1977 F250 4WD from serial # Y20,001 / 1978/79 F250 4WD / 1979 F350 4WD
Bendix P/S: 1966/68 F100/250 2WD, 1969 F100/250 2WD before serial # D96,001.
** Peeps recommend using 1973/79's cuz there's more around, most have P/S...and disc brakes.
Note: F350's were not available with Bendix P/S / 1965 F100/350's were not available with P/S
Note: 1973/75 F100 4WD, 1975 F150 4WD, 1973/77 F250 4WD (High Boys, 1977's before serial # Y20,001) were only available with Power Assist P/S
Old 01-01-2012, 03:29 PM
66f-100's Avatar
66f-100 66f-100 is offline
66f-100 is starting off with a positive reputation.
You can keep your steering wheel from your '66. You just have to grind off a little off the top where the steering wheel attaches. Grind it even with the threads and you will be fine. I also reused the original collar that houses the turn signal switch because the new one had a hazard switch in it and my truck already had one on the dash. Now it looks completely original.
Mark
Old 01-01-2012, 05:02 PM
66f-100, I hoped to do what you did. I'm also going from a 3 speed to an automatic and I definitely want the column shifter. I don't think there is the option of reusing the turn sig switch column. I don't have hazards so I am going to make use of the accomodation on the new column.
Old 01-01-2012, 05:32 PM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
Quote:
Mark
If you guys do this than put the on BEFORE grinding down the end of the shaft. That way when you are done grinding removing the nut will chase the treads. I also taper or bevel the top a little so it looks like the end of a standard bolt. Otherwise you may play he!! getting the nut started ever again. Happy New Year to all.
Arctic
Old 01-04-2012, 07:10 PM
ffflash480 ffflash480 is offline
ffflash480 is starting off with a positive reputation.
Just a question about the cooling tube that attaches to the frame, is it really necessary?
Old 01-05-2012, 07:39 AM
gfpilot's Avatar
gfpilot gfpilot is offline
gfpilot is starting off with a positive reputation.
Quote:
I would say yes if you want to get service life out of your PS unit. As in tranny heat is your enemy here.
Old 01-05-2012, 12:32 PM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
It is not, a substitute can be used. The system does need some cooling. I have seen a small one that connects to the pump. There is enough air flow going through there to support one.
John
Old 01-05-2012, 05:59 PM
jagergirll's Avatar
jagergirll jagergirll is offline
jagergirll is starting off with a positive reputation.
Licoln PS fit too
I used a PS system out a a 78 lincoln it fit just fine then I put a GT steering wheel on it and hooked the horn up everything worked fine. I can send you pictures if you want
Old 01-06-2012, 06:00 PM
BigMikeUGA BigMikeUGA is offline
BigMikeUGA is starting off with a positive reputation.
I just did the conversion and used a Derale (Made in USA) tranmission cooler. The only difference between that and their power steering cooler is the trans cooler has brackets for mounting. I didn't want to attach it to the radiator since I might be adding a/c down the road.
http://www.amazon.com/Derale-13222-F...5890773&sr=8-1
This is mounted to the inside of the frame rail using "L" brackets bent to 45 degrees.
Old 01-06-2012, 06:51 PM
I like that, I am not going to add A/C so I think I will put it up front. Thanks for the pic. And thanks to all for the help...
Old 01-06-2012, 07:20 PM
dhyayi dhyayi is offline
dhyayi is starting off with a positive reputation.
Quote:
Amazon.com: Derale 13222 Frame Rail Transmission Cooler: Automotive
I bought this cooler to use as a power steering cooler on my 1974 Bronco. It was perfect! it was easy to install and i didnt need to buy anything else to install it.
390fe motor mounts help!!! Josh Hopkins 1967 - 1972 F-100 & Larger F-Series Trucks 1 10-22-2016 03:23 PM
I have a power steering question ibewshooter 2015+ F150 2 04-22-2016 08:46 AM
2006 f-350 Diesel leaking Power Steering fluid Rick2006 1999 to 2016 Super Duty 3 03-28-2012 02:24 PM
71 F100 STEERING COLUMN FESTUS65 1967 - 1972 F-100 & Larger F-Series Trucks 4 09-29-2011 03:51 AM
power steering Kalve General Automotive Discussion 7 04-23-2010 11:36 PM
Tags
1963, classifieds, conversion, f250, internet, michigan, northern, online, power, powered, satellite, speed, steering, test, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
