F100
  #31
Old 01-12-2012, 07:38 AM
Thomo5150's Avatar
Thomo5150
Thomo5150 is offline
My cell phone camera sucks, is noted..........
  #32
Old 01-12-2012, 08:11 AM
earthquake68's Avatar
earthquake68
earthquake68 is offline
No offense, ....just sayin'!
  #33
Old 01-12-2012, 08:49 AM
jim collins's Avatar
jim collins
jim collins is offline
I had the same problem with my cell phone camera. I bought a new camera,but still learning how to operate it. Please keep the pictures coming,good or bad, i like what i see. Do you have to change the body mounts ? I see you have removed the right front one.
  #34
Old 01-12-2012, 09:25 AM
JJJRoberts's Avatar
JJJRoberts
JJJRoberts is offline
That is pretty cool I don't think I would attempt a Chevy in a Ford ( Grampa would come back from the dead to see me lol ) but that is going to be center of attention where ever you go good luck can't wait to see the finish product.
  #35
Old 01-12-2012, 01:30 PM
Thomo5150's Avatar
Thomo5150
I'm removing them to mod them 1/2 an inch on the mounting hole, i'll bolt them back on instead of using rivets.
  #36
Old 01-12-2012, 05:28 PM
Thomo5150's Avatar
Thomo5150
I posted this on the Lateral G forum, hopefully it will explain what im doing..........
I started doing this to another type of chassis, it ended up be considered by the Licencing Engineers an individual build because of the chassis mods. This is where the money pit started with torsion tests before and after the frame was modified. I fitted the ZR1 brakes to it and when the Engineer saw those he told me im not allowed to run them because I did not have ABS braking fitted. I sold the chassis to guy in another state who is finding it easier to get licenced.
SO WITH MY SPARE PARTS i STARTED THE f100.
Reading the law that my licencing state has with modified cars I found a loop hole on chassis mods. It says a chassis must not be cut at any point from the cab forward. The rear section is allowed to be modified, ie lengthed etc...
I asked my engineer about replacing crossmembers he said no welded crossmember where allowed to be removed. I asked what if they where bolted and riveted to the chassis? He said yes I can remove and replace them. I asked can I bolt another subframe / cradle between the chassis rails. He said yes.
I asked if I was allowed to modify the chassis behind the cab, he said yes as long as the chassis rails where boxed and strengthed where they have been cut.
So with there restrictions the F100 build has started. I'll be pushing the law with a hole in the chassis for the steering arms to run thru, the law says im not allowed to cut the chassis, nothing about punching a 4 inch hole thru it.
As you can see from the blueprints below im only changing the crossmembers on the chassis and doing a reverse Z on the rear rails bringing the rear rail width down from 37 odd inches to the Corvettes 32 inch rear cradle width. I need to make this chassis look stock so except for the crossmembers and boxing the chassis the original chassis profile will remain the same.
Sometimes you have to build cars to the law, Im not sure what its like in the USA it seems you guys have more freedom to make anythying. I'd luv to build a custom chassis like Roger, Ron, Garage Dog and others have done with the Corvette drivetrain but it would sit in the garage and never be driven. (Driving an illegal car in Western Australia, $1000 fine and they impound the car for a month) Sometimes you gotta comply with BIG BROTHER........
Sorry about the long answer I hope that explains what I am doing and why im doing it.
P.S With the firewall not needing to be modified I can now take my WHEELBARROW back to the hardware store and get my money back.:woot:
Sorry its a :lateral: joke..............
  #37
Old 01-12-2012, 07:48 PM
RunninD's Avatar
RunninD
RunninD is offline
"P.S With the firewall not needing to be modified I can now take my WHEELBARROW back to the hardware store and get my money back.:woot:
Sorry its a :lateral: joke.............."
hahaha. When I read that I had to send you build thread to a buddy. It only took ten minutes before he called back laughing!
My first drag car and his were built side by side in his dad's garage. Our wheel tubs? carved out of several 55 gallon steel drums!!! His dad was one of the coolest builders I've ever met, and told me when I asked why we were using the barrels "If its stupid, but it works, then its not stupid." 5 bucks each for the barrels which could be cut to whatever size wanted and they were thicker than the ones from the auto parts supplier.
Ingenuity my friend, It's called ingenuity
  #38
Old 01-12-2012, 08:14 PM
earthquake68
A fabricator will get this immediately. It's funny, but hey, it works!
  #39
Old 01-12-2012, 08:42 PM
Thomo5150's Avatar
Thomo5150
This is the link for the Wheelbarrow joke..........
ATS 50/50 Camaro - Page 8 - Lateral-g Forums
Read this thread I cant believe the guy paid money for this work...........
  #40
Old 01-12-2012, 09:11 PM
JB78f150's Avatar
JB78f150
JB78f150 is offline
That is a sweet build will have to keep an eye on it.
  #41
Old 01-16-2012, 02:15 AM
Thomo5150's Avatar
Thomo5150
Quick update, I've asked Ben Hermance to do some renderings of the F100 with the body mods, here's some idea's I've sent to him.
Before photoshop.
After
Grill mods.
Chassis final mock up.
  #42
Old 01-18-2012, 06:39 PM
Thomo5150's Avatar
Thomo5150
Final design, this 76 will have some body mods, lets see who can pick them out on this photoshop version.....
  #43
Old 01-18-2012, 06:51 PM
JB78f150's Avatar
JB78f150
JB78f150 is offline
Gas cap, mirrors shaved. The bump is shaved. The cowl seems filled. Bed posts filled. Running light shaved. And this is a bump instead of a dent.
  #44
Old 05-21-2013, 09:23 AM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
No posts in over 16 months.....Has this build withered on the vine?
Subscribing...
  #45
Old 05-21-2013, 09:56 AM
bighatchy's Avatar
bighatchy
bighatchy is offline
Subscribing...
I saw another thread of the same build on LS1tech in a similar condition. I was wondering if he ever completed it or what too
Her55
Projects
03-29-2020 06:42 PM
midfifty
10-31-2014 09:36 AM
cheddar89
Missouri Chapter
17
05-18-2012 07:32 AM
NorCal_AL
13
02-09-2012 03:31 AM
my69
13
07-23-2011 12:28 PM
Quick Reply: F100
