BENT RIM ??????? - Page 2 - Ford Truck Enthusiasts Forums
BENT RIM ???????
Old 01-01-2012, 02:20 PM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is offline
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
I had a set of BF Goodrich tires years ago. They were great, except one went out of round on me. Took it in and they did the same thing. Told me my rim was bent. While on the machine they told me what I was seeing was the rim, but all that was moving was the tire. They refused to replace it. Went to a tire dealer just down the road, had them look at it. They came back and said the tire had failed. To say the least, I don't do business with the other shop anymore, even though the Assistant Manager was a good friend at the time.
Old 01-01-2012, 03:25 PM
Maxium4x4's Avatar
Maxium4x4 Maxium4x4 is offline
Maxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputation
Good to hear. If too much weight is added, time to try another tire.
Old 09-02-2013, 02:06 PM
Fatstrat Fatstrat is offline
Fatstrat is starting off with a positive reputation.
Having same problem with Wal Mart tires (Goodyear Track-2). Truck pulls to the right. Have had front end checked (and repaired), and an alignment. Still pulls. W-M claims 2 bent rims.
Old 09-02-2013, 02:52 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
I Had a problem with Walmart Tires had what's called tread pull
My alignment guy rotated the tires and went away
Old 09-02-2013, 06:23 PM
69cj's Avatar
69cj 69cj is online now
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
No tire or rim from the mfg. is perfectly balanced. When a new tire is mounted to your rim, if the gods are against you that day, all of the disproportionate weight ends up on the same side. A good tech will see that. I had this happen at America's tire once. I happened to see the tire and wheel when they were putting it on the truck with what looked like a 1/2 lb. of weights on one side. I went and got the manager. He had them rotate the tire on the wheel and rebalance and all was well then. A good balance man knows when things aren't right. Luckily the manager was sharp enough to know what I was talking about. The store I went to is a good store but sh** happens some days.
New truck with <20 miles and bad vibrations at 65 lostintexas 1999 to 2016 Super Duty 50 01-15-2017 10:35 PM
Bent Rear Axle? ke7gpu 1999 to 2016 Super Duty 14 06-14-2015 09:57 PM
Warped Hub? ssharber 6.4L Power Stroke Diesel 6 10-09-2012 09:42 AM
hopping/shaking dually -issue resolved. FORDF250HDXLT Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 05-16-2011 08:07 PM
Need some help with what to do - new tires, balanced twice, truck still vibrates bad wogdiml 1999 to 2016 Super Duty 29 11-19-2010 04:52 PM
Tags
2004, 2005, 2010, 2011, 22s, bent, damaged, e150, effects, escape, explorer, ford, problem, rim, rims, van, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
