Ranger Dash Panel Removal: - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 12-31-2011, 08:51 PM
leonharu's Avatar
leonharu leonharu is offline
leonharu is starting off with a positive reputation.
I have a 2003 Ranger XLT that has an annoying raddle behind the center dash panel that goes around the radio and heater controls.I need to remove this panel to see what is going on!Can anyone give me directions on removing this panel without breaking something. Thanks,Russ
Old 01-01-2012, 03:03 AM
Rangerman Stan Rangerman Stan is offline
Rangerman Stan is starting off with a positive reputation.
You may be able to have more access to the center area by taking out the radio/cd player. There should be two holes on each side of the radio that you can insert a release tool into, in order to pull out the radio. Once the radio is out you can unplug it and set it down out of the way. Also once the radio is out you can remove the bezel that goes around the radio, vents and heater controls. Take out the two screws that are seen between the opening for the radio and the opening for the heater controls on the outside of the bezel. Once these screws are out you should be able to pull the bezel off if you can get your finger nails or a slim piece of metal between the bezel and dash and pull straight out. It has metal fingers on the back that go into plastic sockets to hold it in place. You can also go under the dash from each side to get to the center down low by the floor mounted drink holder. For removing the radio, you can buy a set of two release tools at a auto parts store for only a couple of bucks. Or you can make some from coat hangar that will work good if you use a coat hanger that is made from the larger diameter wire. The release tools look like an extra long horse shoe that has straight ends instead of going on around in a bend and are about 4-5" long each. Insert each end of one tool into the holes in the side of the radio case. They only need to go in about an inch and a quarter to engage the lock clip on each side. When inserting the tool in each side you don't need to push very hard or the tool can go in too far and not engage the clip correctly. Once both tools are in place, push outward to the left on the left tool and outward to the right on the right tool. Push in slightly on the radio first so the clips will be free of the inner panel. While you maintain the outward pressure on both tools then try to pull the whole radio toward you either by getting a finger into the tape player slot and pulling or by pulling on the release tools and trying to wiggle the radio at the same time to get it to start moving out. If you buy the radio removal tools it may be easier to get it to come out because they have a notch at the end of the tools to help grab the clip and make it easier to pull it out. With either the radio out or the bezel off you should be able to get to your rattle source. Let us know how it goes.
Old 01-01-2012, 07:00 AM
03 Maz B23 03 Maz B23 is offline
03 Maz B23 is gaining momentum as a positive member of FTE.
Here's a vid link showing dismantling dash to replace cluster bulbs in an Explorer (same dash) but it also shows removing the radio panel as part of the dismantling process.
Ford Dash Lights & Shift Indicator Repair - YouTube
Old 01-06-2012, 01:54 PM
TallPaul's Avatar
TallPaul TallPaul is offline
TallPaul is gaining momentum as a positive member of FTE.
I pulled the radio on my '95 F150 using 4 nails of the appropriate size. Think were about 2 inch long maybe 2.5, fairly thin. Wear leather work gloves as you have to push fairly hard.
2009 F350 Dash Panel Removal avvidclif 1999 to 2016 Super Duty 1 06-30-2016 11:21 PM
How to remove lower dash panel on a 93 351Cleveland C4 Ranger & B-Series 3 11-05-2015 02:20 PM
Dash Panel JAYS 77 F-250 1973 - 1979 F-100 & Larger F-Series Trucks 4 02-22-2015 06:31 PM
69 f100 ranger dash board and door panels 69jwatson 1967 - 1972 F-100 & Larger F-Series Trucks 5 11-28-2011 12:22 AM
Removing the door panel on a 98 Ford Ranger wolfmanagh General NON-Automotive Conversation 4 03-22-2002 10:32 PM
Tags
1997, 2001, 2002, 86, bezel, dash, ford, instrument, panel, ranger, removal, remove, removeal, stereo, youtube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
