Go Back   Ford Truck Enthusiasts Forums > Diesel > Competition
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Competition Diesel racing, sleds, dynos, power tuning and max performance.
  #1 (permalink)
Old 12-31-2011, 07:47 PM
rkmfordman rkmfordman is offline
2011 Ford F-250
rkmfordman is starting off with a positive reputation.
welding ifs front axle
is it possible to weld an ifs front axle on 87 f250 4x4 to keep it from flexing we use this truck for sled pulling only in pure stock class the ifs toes in really bad when weight comes off the front not letting the tires keep good contact with the track thanks.
  #2 (permalink)
Old 01-01-2012, 11:47 AM
tjc transport's Avatar
tjc transport tjc transport is offline
Garage is empty, add now
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
if you weld the axle, it will become a solid front axle. since there was never a solid axle stock in a 87 F-250, it will no longer be a pure stock truck.
__________________
Tom
JOIN THE NEW JERSEY CHAPTER CLICK HERE
owner of almost too many fords.
  #3 (permalink)
Old 01-01-2012, 05:18 PM
2011 Ford F-250
Quote:
thats true but the rules are pretty lax in the class hardly any of the trucks are truely pure factory stock.one truck is a shortbed 3/4 ton chevy i never seen any of them before from the factory.
  #4 (permalink)
Old 01-01-2012, 05:22 PM
if that is the case, i would just look for a dana 60 out of a F-350 to bolt under it
__________________
Tom
  #5 (permalink)
Old 01-02-2012, 06:11 AM
2011 Ford F-250
did the f350s in the late 80s trucks have a solid front axle?
  #6 (permalink)
Old 01-02-2012, 07:53 AM
after mid year 85
__________________
Tom
  #7 (permalink)
Old 01-02-2012, 04:38 PM
2011 Ford F-250
thanks tjc ill start lookin
  #8 (permalink)
Old 01-02-2012, 04:55 PM
Car-Part.com--Used Auto Parts Market
L & M Auto Salvage USA-KY(Frankfort) (502) 223-0229
has 2 listed. one with 3.54 gears and one with 4.10 gears, $1200 each
__________________
Tom
  #9 (permalink)
Old 01-04-2012, 08:36 AM
wyoming4x4's Avatar
wyoming4x4 wyoming4x4 is offline
wyoming4x4 is starting off with a positive reputation.
limit straps.
set up your suspension with some limiting straps or poor boy a chain system on your truck. strap on each side to keep the suspension from dropping out all the way. if compressing are air bags legal inside coilsprings. also www.autofab.com sells some material to keep the suspension from compressing inside the coil spring. off road race truck stuff. works great for hard compression hits. thats not really your problem but autofab sells straps for many applications. catch you later.
  #10 (permalink)
Old 01-04-2012, 06:21 PM
2011 Ford F-250
Quote:
I never thought about that i believe that would work you just made my day!!Thanx a bunch
  #11 (permalink)
Old 04-19-2012, 08:30 AM
pennsylvaniabo pennsylvaniabo is offline
pennsylvaniabo is starting off with a positive reputation.
Yeh, some people have welded up a ttb 50. You can do so, then cut off the center pivot joints.
Tags
4x4, 50, axle, axle87, axles, diff, differential, f150, ford, front, ifs, truckwelding, weld, welded, welding
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
