Project Midnite UPDATED - Page 6 - Ford Truck Enthusiasts Forums
  #76
Old 03-12-2012, 01:01 AM
Bankrupter Bankrupter is offline
Bankrupter is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Midnite1987 View Post
That's atually the scoop on deljac's truck, I like the way it looks and have been keeping my eye out for one at the JY
~face palm plant~ I plead guilty of looking at just the pics and ignoring relevant information posted with them lol... sucks to see that rear end. Read your other thread asking about the one w/o Vss. I dont have the know how to comment.. it didnt need a bump so I moved on... GL on that issue though, wish I could help...
  #77
Old 03-13-2012, 11:14 PM
Midnite1987's Avatar
Midnite1987 Midnite1987 is offline
Midnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to behold
FINALLY got my pitman arm in the mail. Can't wait to get the steering linkage done and the steerin stabalizer in!
  #78
Old 03-14-2012, 01:47 AM
ordered new accumulator valve springs and a filter stay put clip to hopefully fix my harsh shifting. that b&m kit is comming out
  #79
Old 03-15-2012, 12:50 AM
traxx808's Avatar
traxx808 traxx808 is offline
traxx808 is starting off with a positive reputation.
hey midnite, did you find out why your rear end does that. i think mine does it also but, now as bad as yours. mines feels like after i put it in gear and i let go of the brake and step on the gas theres a small slip ( i can feel and hear a slight movement before the truck moves.) i was wondering if there was something wrong with my gears or the diff was going out. my gears are new. only about a year old. what do you think it could be midnite? think its the diff?
  #80
Old 03-15-2012, 12:55 AM
after opening up mine and looking inside the spider gears looked a little work but thats about it. i compared the axle rotation to my other truck and it moves about the same amount but its softer when it shifts. so that makes me think the shift kit i have is screwing things up. so im going to go back with stock springs again once they show up
  #81
Old 03-15-2012, 01:53 AM
traxx808's Avatar
hey midnite, i forgot to mention that i have a b&m shift kit to. i set it up for the strip and it shifts hard but, i'm comfortable with it. could be the diff is worn due to it not being built for that purpose (rear end). i already got a bare rear end for free so now i was thinking of building it up to handle the shift kit and future engine rebuild. hopefully this rear won't blow anytime soon. ( i hate tooting my own whistle ). gonna cross my fingers.
  #82
Old 03-15-2012, 02:02 AM
I ha mine setup for strip at first then swappe to the lighter springs but don't notice much difference. So I'm just goin to go back to stock springs and see if it helps
  #83
Old 03-15-2012, 02:11 AM
traxx808's Avatar
keep us up dated on the tranny. i would like to know how much it helped you if any at all.
  #84
Old 03-16-2012, 09:32 PM
Replaced the inner/outer tierods and pitman arm.
Installed a rancho steering stabalizer ( guy at work bought it 12 years ago and never used it. I got it when he cleaned out his garage.
Found a doormat with rubber bottom on sale. Laid it out on the folded flat backseat maybe stuff won't slide around now. Like my sub box mainly
  #85
Old 03-18-2012, 12:11 AM
man does it ever steer nice now with the new linkage!! it was getting pretty sketchy near the end.....
was quoted 150$ for an allignment and 100$ to install the new camber bushings.
i figured they have to adjust them anyways so it might be easier if they just install them too.....
now to wait for my unemployment to come in so i can get an allignment done.(im in school for 8 weeks. ill be a 4th year apprentice millwright when i get out)
  #86
Old 03-21-2012, 01:52 AM
Just when things were all commin together......
Pop.....hissss.....hissss....hissss.....hisssss... Then the feeling of drivin on a flat.....
Then not even 5 min later my girlfriend calls and says her tire blew..... Like WTF! What a day....
  #87
Old 03-21-2012, 09:33 AM
minnesotafisherman's Avatar
minnesotafisherman minnesotafisherman is offline
minnesotafisherman is starting off with a positive reputation.
Ouch that sucks. Glad I got a spare 33 with the other four I bought in case this happens to me.
  #88
Old 03-21-2012, 09:52 AM
Grubbworm's Avatar
Grubbworm Grubbworm is offline
Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.
Where was your spare, Midnite?
  #89
Old 03-21-2012, 01:27 PM
I only got 4 32" tires when I got mine. Got them from pick n pull and spare didnt come with it.
Going I replace the 2 rear tires with new 32-11.5 15 BFG at's for now then once I get an allignment I'll replace the front 2. Then I have 3 spares....
BUT I want to go with 33 12.5 15 then they're more common. I found a set of 5 for 1000 used with 2000km on them.... So I don't know
  #90
Old 03-22-2012, 11:38 PM
well i SCORED on a set of 33 12.5 r15 BFG AT tires with 12/32" tread left, had 17/32" new. no un even wear. but there are some small cracks in the tread. but for free... i wasnt going to argue. the PO had them on a 7" wide rim so im thinking that was part reason for them to start to show cracks.....
also picked up a set of procomp 15x9.5" rims to mount the tires on . going to clean up the rims and give them a coat of paint tomorrow so i can get the tires on this weekend.
Mr. Meyer's 4 bolt main's & some yates junk . . . mustange70 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 19 06-26-2014 01:13 AM
Top chop 65 facusessa 1961 - 1966 F-100 & Larger F-Series Trucks 39 07-10-2013 10:34 AM
New tires! (pictures) acf6 1999 to 2016 Super Duty 129 04-24-2013 05:54 AM
Let the games begin! LWW Excursion - King of SUVs 16 12-17-2011 06:12 PM
Big front bumper improves MPG Low and Mean 1968-2013 Full Size Vans 17 11-04-2011 01:40 PM
Tags
194r, 2006, article, audio, bug, dash, dashboard, deflector, f150, f250, home, kenwood, led, lights, powered, red
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
