Project Midnite UPDATED - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 01-29-2012, 09:16 PM
Bankrupter Bankrupter is offline
Bankrupter is gaining momentum as a positive member of FTE.
Midnight I know you like the higher head light pattern of the lifted truck but you need to re aim them so your low beams are not blinding to oncoming traffic. Looks good!
  #47
Old 01-29-2012, 09:23 PM
Midnite1987's Avatar
Midnite1987 Midnite1987 is offline
Midnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to behold
The truck went up 2" in the front and 2.5" in the rear. I don't the low beams to be about the same distance away on the road. The headlight pics are after the HD harness and the lift. There's not much of a difference. Here's a before and after at about 20' away from the house. They are basically the same height....
Before
After
  #48
Old 01-29-2012, 09:30 PM
the center of the beam is lower in the after pic lol thats odd
  #49
Old 01-29-2012, 09:35 PM
It's still pretty close to stock. I'm thinking the 1/2" higher in the rear was enough to make It lower. ( I might not be in the exact spot in both pictures. But in the same distance back as I backed up to my shed)
  #50
Old 02-03-2012, 08:07 AM
88dually 88dually is offline
88dually is gaining momentum as a positive member of FTE.
did you also change bulbs? how hard was it running the lights off the batt ?
  #51
Old 02-03-2012, 08:25 AM
Took me bout an hour to wire the lights in not hard to do.
The bulbs are not the stock ones. They are suppsed to be "white" light, got them as a gift so I'll use them till they burn out
  #52
Old 02-03-2012, 08:32 AM
thats good, i suck at electrical. I did silverstar ultras on wifes car an the results between our 2 almost look the same. Now i'm thinking about running the lights on her jeep to the batt. Trucks looking good, a small lift like u did makes these trucks look so much better, just enuff, an not too much.
  #53
Old 02-18-2012, 06:01 PM
Well scored a set of 32-11.5r15 on the factory ford aluminum wheels And a visor
Here's a before shot
The tires on they rub on full lock but not bad. Ha to remove mudflap... Tires caught it lol
Tires and visor
Sprayed the visor black
  #54
Old 02-18-2012, 06:07 PM
minnesotafisherman's Avatar
minnesotafisherman minnesotafisherman is offline
minnesotafisherman is starting off with a positive reputation.
Quote:
Looks awesome! I'm looking for a summer set of 33's myself.
Last edited by minnesotafisherman; 02-18-2012 at 06:08 PM. Reason: removed duplicate pics from quote
  #55
Old 02-18-2012, 07:17 PM
Truck looks real nice with the tires
  #56
Old 02-18-2012, 08:19 PM
F350Kid238 F350Kid238 is offline
F350Kid238 has a good reputation on FTE.F350Kid238 has a good reputation on FTE.
looking good man
  #57
Old 02-18-2012, 08:33 PM
fount out that my inner tierod end at the pietman arm is loose. looks like the nut backed off but the cotterpin is still in it. so i just ordered a full steering linkage kit of ebay with both outer and inner pieces and the adjusting sleeves. now to order a pitman arm as well i think the hole is worn.
guess that would have caused my sloppy steering
also getting a steering stabilizer kit for next to nothing from a guy at work. he bought it 15yrs ago for his ranger and it didnt fit so its been on his shelf.
  #58
Old 02-18-2012, 09:08 PM
well today was an expensive day.
pick n pull $250 - tires/rims, visor
ebay- $300 - new pitman arm, complete steering linkage and extreme camber bushings...
ouch
  #59
Old 02-18-2012, 09:09 PM
Quote:
Quote:
Originally Posted by F350Kid238 View Post
looking good man
Quote:
thanks guys, im really liking how its comming along.
  #60
Old 02-18-2012, 09:13 PM
deljac's Avatar
deljac deljac is offline
deljac is gaining momentum as a positive member of FTE.deljac is gaining momentum as a positive member of FTE.
the only thing i dont like about my visor is when it rains or the snow is melting, it drips alot onto the windshield but oh well i love how they look. i just realized you had asked for a closer pic of my hood scoop. i will take one tomorow
Top chop 65 facusessa 1961 - 1966 F-100 & Larger F-Series Trucks 39 07-10-2013 09:34 AM
whats the coolest project you have built? ( not car related) im2tall33 General NON-Automotive Conversation 107 04-29-2012 01:58 PM
I got the Gotts!!!! SCRWDRVR 2004 - 2008 F150 15 02-06-2012 02:50 AM
2011 Explorer acf6 2011 & Newer Explorer 17 10-30-2011 11:10 AM
My 66 project superbean 1961 - 1966 F-100 & Larger F-Series Trucks 33 05-06-2011 02:10 PM
Tags
194r, 2006, article, audio, bug, dash, dashboard, deflector, f150, f250, home, kenwood, led, lights, powered, red
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
