Project Midnite UPDATED - Page 18 - Ford Truck Enthusiasts Forums
  #256
Old 08-27-2012, 07:22 AM
wicat3's Avatar
wicat3 wicat3 is offline
wicat3 is starting off with a positive reputation.
Looks like a fun camping trip. Sucks you are looking to sell it but that happens.
  #257
Old 08-27-2012, 10:23 AM
deljac's Avatar
deljac deljac is offline
deljac is gaining momentum as a positive member of FTE.deljac is gaining momentum as a positive member of FTE.
Sorry to hear your wanting to sell but i understand. Goodluck on ur search
  #258
Old 08-27-2012, 10:33 AM
Midnite1987's Avatar
Midnite1987 Midnite1987 is offline
Midnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to behold
ill still have my 95 2wd f150 to play with
  #259
Old 08-27-2012, 11:31 AM
KingBigJoe's Avatar
KingBigJoe KingBigJoe is offline
KingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputation
Quote:
Same here...
  #260
Old 09-07-2012, 07:54 PM
Well I realized how much the truck meant to me so I'm keeping it. It has 1ton leafs under it now to help with the weight.
On another note...
DELJAC, what did you use to paint your bumper black? I think I have asked you this before I just can't remember. It's the last bit of chrome on the front and I want to paint it black..
  #261
Old 09-08-2012, 05:59 AM
KingBigJoe's Avatar
I'm glad you couldn't let your truck go.
  #262
Old 12-29-2012, 02:08 AM
well i finally have something to update to the thread lol
had an 11hr day with PUDDY at my work working on my truck.
started with removing motor mounts. and oil pan gasket.
ended up picking motor as high as we could get it (and i have the 3" bodylift too) to drop the oil pan. unbolted pan and oil pump. tried our best to get it out without removing the y pipe but no luck. didnt want to chance breaking a stud on the exhaust so just cut the section out that ran under the motor to give enough room to remove oil pan. once pan was out sandblasted and found a hole, so welded the hole up. painted the oil pan and cleaned the oil pump. re assembled the pump/pan using a new felpro gasket.
installed the new super duty motor mounts from bronco grave yard and a new transmission mount again.
filled with the cheapest oil i could find to do a flush and moved truck across the shop to the welder so i could weld the exhaust back together.
man i love the sound with basically open headers.....
<iframe width="420" height="315" src="http://www.youtube.com/embed/uZPKvIV9Tzk" frameborder="0" allowfullscreen></iframe>
re welded the exhaust and its good as new now.
BIG thanks to PUDDY for all the help today.
get to do it all over again to his truck in a couple weeks lol
few pics
  #263
Old 12-29-2012, 05:06 AM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
Man, that looks like a J O B ! Good thing to have good help and some super resources.
  #264
Old 12-29-2012, 01:14 PM
Quote:
Exactly. I wouldn't have tackled this on my own. Not until I had a garage at home and can take me a few days to do it or just pull the motor lol
  #265
Old 12-29-2012, 02:27 PM
Puddy's Avatar
Puddy Puddy is offline
Puddy is a splendid one to beholdPuddy is a splendid one to beholdPuddy is a splendid one to beholdPuddy is a splendid one to beholdPuddy is a splendid one to beholdPuddy is a splendid one to beholdPuddy is a splendid one to beholdPuddy is a splendid one to behold
What size was the bolt for the motor mount again, 16 or 18mm?
  #266
Old 10-27-2014, 05:47 PM
justinw77 justinw77 is offline
justinw77 is starting off with a positive reputation.
Need handles in my truck.
Quote:
Originally Posted by Midnite1987 View Post
well i grabbed a handle out of a 2000f150 for ther pillar and a handle from a 98 contour for above the door.
after looking into it and measuring and stuff i decided the pillar ones wouldnt work for me so i installed the contour oned above the door. i used rivet style "nuts" if you want to call them that. the handle is nice n sturdy. i spaced it out with a 1/2" nut so it didnt pull into the headliner
Did you have to drill a hole in the headliner? Where did you get the screws?
Thanks
  #267
Old 11-01-2014, 11:35 AM
Quote:
Originally Posted by justinw77 View Post
Did you have to drill a hole in the headliner? Where did you get the screws? Thanks
Yes I drilled a hole in the headliner and in the inner florid skin for the nutsert.
The nuts were like a rivet tighten them and it fastens it self to the sheet metal. Had them at work
Top chop 65 facusessa 1961 - 1966 F-100 & Larger F-Series Trucks 39 07-10-2013 10:34 AM
I got the Gotts!!!! SCRWDRVR 2004 - 2008 F150 15 02-06-2012 03:50 AM
Pictures of my Ex Off Road Flawless_X Excursion - King of SUVs 23 12-16-2011 12:31 AM
turndowns under bed? UPDATED vid Midnite1987 1987 - 1996 F150 & Larger F-Series Trucks 19 10-16-2011 07:15 PM
My project.... rmodel65 1973 - 1979 F-100 & Larger F-Series Trucks 11 08-18-2011 02:58 PM
Tags
194r, 2006, article, audio, bug, dash, dashboard, deflector, f150, f250, home, kenwood, led, lights, powered, red
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
