Help with misfire - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Help with misfire
Old 12-31-2011, 05:34 PM
NorthTitan33 NorthTitan33 is offline
NorthTitan33 is starting off with a positive reputation.
Help with misfire
2000 Ford F-250 V-10 Gas.
Drove the truck from San Diego to Tennessee, no problems whole way.
Here for about a month and once the truck got warm it would begin sputtering. Thought it was misfire. Threw a code and sure enough it's misfire on cylinder 1 and 9. Two cylinders same time. Crap. So I throw some injector cleaner in it and no change.
So I move the injector of cylinder 1 to cylinder 2 and the coil of cylinder 1 to cylinder 3, so that if it trips 2 or 3 I know which part went bad. Do the same thing for cylinder 9, move injector 9 up to injector 7 and coil 9 to coil 8.
Drive the truck again, same thing. Truck drives fine at first then begins to sputter about the time the engine gets warm. Once again got the code read expecting it to be cylinders 2, 3, 7, or 8. Well if it had been I wouldn't be asking for help. Cylinder 5 threw a code. Double crap.
While driving, the sputtering is not consistent, sputtering stops and starts no matter if I am going up hill or down hill, slowing down or speeding up. It just comes and goes. So what's everyone's input?
Old 12-31-2011, 07:49 PM
2003 f-250 2003 f-250 is offline
2003 f-250 is starting off with a positive reputation.
possible bad gas, dirty MAF, or bad plugs. Trust me, the plugs can go bad. I had two go bad in less than 3000 miles... Worse comes to worse, take it to your local ford dealer and spend 100 bucks on a diagnostic test. Only their scanners/computers will communicate well with the truck.
hope this helps
Old 12-31-2011, 09:58 PM
PX29 PX29 is offline
PX29 is starting off with a positive reputation.
Common problem with modular engines.
Replace your plugs and coil packs before you ruin the catalytic converter.
Accel makes lower cost coil pack kits. Use Autolite APP103 plugs.
Take your time. It is a PITA job. The old boots may stick to the plugs. Blow the dirt out of the plug holes before removing the plugs. Use dielectric grease on the boots. Anti-seize on the plug threads. Get a swivel spark plug socket too. Makes the job go better.
Old 01-01-2012, 02:12 AM
Replaced the plugs when I bought the truck, about 5000 miles ago. How would sporadic misfires mean a bad plug? If the plug was bad wouldn't it always misfire same cylinder? I just don't get why I would get a sporadic misfire. I will check those ideas though. Which one is the MAF? I get MAF and MAP mixed up all the time.
Old 01-01-2012, 12:58 PM
jh818's Avatar
jh818 jh818 is offline
jh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputation
MAF is the sensor in your air filter housing.
Old 01-01-2012, 01:19 PM
if that was bad wouldn't it throw a code? what would be bad about it? something internal that I wouldn't be able to see?
Old 01-01-2012, 01:46 PM
Hotpocket's Avatar
Hotpocket Hotpocket is offline
Hotpocket has a good reputation on FTE.Hotpocket has a good reputation on FTE.Hotpocket has a good reputation on FTE.
might not be bad might just need to be cleaned as stated above you can get some cleaner from the parts store
Old 01-01-2012, 02:39 PM
PA-Mark's Avatar
PA-Mark PA-Mark is offline
PA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputation
In the Army, when our weapons missfired we would apply S.P.O.R.T.S.
Slap Pull Observe Release Tap Squeeze...... Hope this helps
Mark
Old 01-01-2012, 05:38 PM
jmiley jmiley is offline
jmiley is starting off with a positive reputation.
Be careful of the type of anti sieze you use, I would just use dielectic grease, anti sieze with copper in it will ruin the heads.
Old 01-01-2012, 06:12 PM
well the fact that my misfires are random, i'm guessing that it's not my plugs. i pulled a couple just to check though and they looked fine. ill try to clean the MAF next and see what happens. maybe my gas is just that bad that the injector cleaner didn't help it? maybe ill try the lucas oil fuel stuff.
Old 01-01-2012, 06:41 PM
Quote:
I have just gone through this, trust me.... it's aggravating. The best thing to do like I said in my first reply, is to go to your local ford dealer and just have them diagnose it. Don't let them fix it for you b/c you can buy 8 motorcraft plugs from autozone for the price of two from the dealer. Also, may I ask what plugs you used? I used Autolite 103's and I burnt up two of them in 3000 miles. The plugs look fine, but trust me..... they can be bad.
hope this helps!
p.s.
I'm not saying that the plugs are bad.... just a good chance that they could be. It can be lots of things from a vacuum leak, to a bad coil pack, bad ground, bad plugs, the list goes on and on. I spent 800 bucks and all I ended up truely fixing was the two plugs that the dealer told me was bad.
Old 01-01-2012, 06:51 PM
I don't remember what plugs I used. I'd have to pull em again and look. I live in farm territory in Tennessee, I don't even know where the nearest ford dealership is and I don't like driving it while it's missing and sputtering. Did you have the same random and sporadic misfires while driving?
Old 01-01-2012, 06:54 PM
PA-Mark's Avatar
if you going to go through the trouble of pulling them, do yourself a favor and do a resistance check on each plug, like was said erlier... they may look good but may not be
Mark
Old 01-01-2012, 07:10 PM
Took it to a mechanic of mine and had him hook it up to his snap on scanner(the newest/most updated one on the market). Also Remember, it took me 500 miles of driving to finally get the damn thing to through a cel. Anyways, his scanner did nothing more than what the cheap scanners @ autozone do. Ford has in my opinion the greatest upper hand with these trucks because they are set up for obd2 but are really only obd1(or atlest my non ca one is), so all the "normal" scanners can't communicate very well with the truck. I would just get hesistation and miss fires. I checked everywhere for vacuum leaks, clean the throttle body, cleaned the IAC, cleaned the MAF ( be careful and read directions when you do this otherwise you'll ruin it ), changed all the coil packs, and I can't remember what all else. to no avail.
Similar to your experience, The truck drug a 38' gooseneck on a 1200 mile round trip (picking up some farm equipement from wisconsin) having the **** drove out of it and it never missed a beat. A week later I started having the miss fires. Drove the truck for over a week trying to get a cel to come on. Long story short, I took it to ford even though I don't trust any dealership because no matter if they breake something ....it's always "it was like that when it came here" or "we're not responsible for....." But they showed me the fuel maps from the truck and switched some of the coil packs and plugs around and figured out what actually was wrong. Due to my truck not having a cat on it anymore and the increase of ethanol in the fuel, alot of vehicles run lean. Whether I just got a bad set of Plugs, or if it was increased heat/stress from the lean condition....I ruined a set of plugs. Even though the plugs were bad, they'd still fire under some/most of conditions but would miss under others (mainly under load or cold)
If you can't take it to a ford dealer, then I suggest you look for vacuum leaks, then replace the coil packs if they haven't been (get ones from ebay, I can give you a link if you'd like for "said" motorcraft surplus cops ) and put in motorcraft plugs from autozone. Also, have you changed your fuel filter lately???? (or has it ever been changed period????)
Hope that some of this story book I wrote helps you. Feel free to pm me if you'd like, or you can look @ my profile at the posts/threads that I've posted when I was having troubles.
Thanks,
Robert
Old 01-01-2012, 07:13 PM
where can i find proper resistance for my plugs? and it's the resistance between the two ends?
5 different fault codes naiku 1997 - 2003 F150 8 12-21-2016 06:51 AM
1999 5.4 random misfire, chasing my tail Bootlegger's Deluxe Modular V8 (4.6L, 5.4L) 2 03-12-2016 09:51 PM
2004 Ford F150 5.4 Triton 3V Vin5 Rough Idle Cylinder 3 Misfire Wildboy402 2004 - 2008 F150 12 12-24-2015 01:42 AM
5.4 random misfire HappyRanger 1997 - 2003 F150 5 02-21-2014 02:06 AM
truck sputters swascott1981 Ranger & B-Series 11 03-21-2012 06:02 AM
Tags
2003, 2007, duty, expidition, f250, ford, misfire, northern, piercing, probe, super, tool, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
